One-Stop Solution Provider for Your Jetson Camera Applications
Arducam Cameras for Jetson
Arducam is a camera solution provider for embedded systems that help you use cameras better and use better cameras on Jetson Platforms.
For a long time, we tend to borrow off-the-shelf Raspberry Pi cameras for Jetson applications. However, the official Pi cameras are not easily customizable, and cameras other than that come with little driver support.
With Arducam, you will not only have access to better Pi-like IMX219 and IMX477 cameras but also interface to other camera sensors that Arducam makes possible on the Jetson Platforms. Aside from that, we also made multiple cameras easier.
Jetson-Native IMX219 and IMX477
The native cameras are the camera modules that officially supported by the Jetson hardware with the driver and ISP support. At the moment, two camera modules IMX219 and IMX477 are natively supported, they can cover most of the use-cases. So if you are new to Jetson and want to use the camera with the existing on-line opensource code that uses native camera commands like nvgstcapture nvarguscamera, or nvargus API, etc.
| 8MP IMX219 | 12MP IMX477 |
| stock lens, drop-in-replacement (Autofocus, low distortion, wide angle), M12 mount, CS mount, PTZ | CS Mount, CS Mount with housing and HDMI Adapter, M12 Mount Mini |
Arducam Jetvariety Series to Increase Camera Varieties
If you are an advanced user and find that the native Jetson MIPI cameras don’t meet your requirement, you can have a look at Arducam Jetvariety cameras.
Jetvariety is an Nvidia Jetson platform V4L2 kernel camera driver framework that can support any MIPI cameras Arducam provides which are not natively supported by the Jetson. A single-camera driver for all is the main goal of Jetvariety project, the users don’t need to develop their camera driver for Nvidia Jetson boards.
| RAW Data | On-Board ISP |
| OV7251, OV9281, OV2311, IMX135, IMX298, AR1820HS, IMX230 | AR1335-OBISP, AR0230-OBISP |
UVC camera
If you don’t want to use CSI-2 MIPI cameras, but want to try USB cameras for some reason. You can check Arducam USB2.0 UVC camera solution from our list.
Arducam 8MP Varifocal USB Camera Module, 4K CMOS IMX179 UVC Webcam Board with 2.8-12mm Zomm Lens, 6.56ft/2m Cable for Windows, Linux, Android and Mac OS
[Discontinued] 1080P Low Light Low Distortion USB Camera Module with Microphone, 2MP IMX323 Mini Webcam
[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7″ CMOS AR0230 100 Degree Mini UVC USB2.0 Webcam
8MP 1080P USB Camera Module, 1/4″ CMOS IMX219 Mini UVC USB2.0 Webcam
Arducam USB Camera Shield – Camera Building Blocks
If you found the UVC camera has limited bandwidth and want to connect multiple USB cameras, you can check our USB3.0 camera shield to DIY a camera.
USB camera shield is a basic camera building block that helps you to create a USB camera as easily as Lego bricks. Together with other camera building blocks from Arducam, like the camera breakout board, the MIPI adapter board, or the HISPI adapter board, you can stack them together to DIY a USB camera. Learn more about the USB camera shield here.
Multi-camera Solutions for the Jetson
Arducam has several different multi-camera solutions to address different use-cases.
![[B01675MP]Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera for Raspberry Pi 4/3B+/3](https://cdn.arducam.com/wp-content/uploads/2019/11/b01675mp_11-1024x1024.jpg)
