8MP IMX219 Cameras , 8MP IMX219 for Jetson
8MP Pan Tilt Zoom PTZ Camera for Raspberry Pi 4/3B+/3 and NVIDIA Jetson Nano/NX and NVIDIA Orin NX/AGX Orin
Buy Now- Real PTZ with servos for directional control and varifocal lens for optical zoom now comes to the Raspberry Pi and Jetson Nano / Xavier NX
- Switchable IR Cut: Through software to achieve your day/night vision
- Make full use of the CSI …
Arducam IMX219 Auto Focus Camera Module, drop-in replacement for Raspberry Pi V2 and NVIDIA Jetson Nano Camera
Buy Now- Native to Raspberry Pi: You don’t need to install additional driver for the camera
- Programmable Autofocus: Software controll, focus closer. See Arducam Github for more details
- Control Precisely: You can use “UP” and “Down” on your keyboard to adjust the …
Arducam IMX219 Auto Focus IR Sensitive (NoIR) Camera Module, drop-in replacement for Raspberry Pi V2 and NVIDIA Jetson Nano Camera
Buy Now- Easy installation: Just detach the original stock IMX219 module onboard and re-attach this replacement
- Motorized Focus Lens:The lens focus is programmable by software
- Wide Application: Drones, robots, action cameras and 3D scanning applications
- Camera board is not included in …
8MP IMX219 for Jetson , Cameras for Raspberry Pi
8MP IMX219 Camera Module with fisheye lens for NVIDIA Jetson Nano/NX and NVIDIA Orin NX/AGX Orin
Buy Now- More Than HD: This camera adopts 1/4” 8 Megapixel IMX219 sensor for sharp image, Max. still resolution is 3280 x 2464 pixels.
- Wider Angle of View: This camera module has 220°(H) wide-angle M12 Lens, which provides …
Arducam IMX219 Camera Module with fisheye lens, drop in replacement for Raspberry Pi V2 and Nvidia Jetson Nano Camera
Buy Now- Easy installation: Just detach the original stock IMX219 module onboard and re-attach this replacement gently and carefully
- Wide Application: Drones, robots, action cameras and …
Arducam IMX219 Low Distortion IR Sensitive (NoIR) Camera Module, drop-in replacement for Raspberry Pi V2 Camera and NVIDIA Jetson Nano
- Low Distrotion Lens: This camera module has low distortion of view (<3%) lens
Arducam IMX219 Low Distortion M12 Mount Camera Module, drop-in replacement for Raspberry Pi V2 Camera and NVIDIA Jetson Nano
- Low Distortion: 70°(H) Low-Distortion (<3%) M12 Lens, minimize the image distortion and wide angle
- Wide Application: Widely used in optical instruments for space exploration, …
8MP IMX219 for Jetson , Jetson Cameras
8MP IMX219 Camera for NVIDIA Jetson Nano/NX and NVIDIA Orin NX/AGX Orin
- Frame Rates: [email protected], [email protected], [email protected]
- Focal Length: 3.04 mm; Angle of View: H=62.2 …
8MP IMX219 Wide Angle Camera Module for NVIDIA Jetson Nano/NX and NVIDIA Orin NX/AGX Orin
- Wider Angle of View: This camera module has 175°(D) wide-angle M12 Lens, which provides …
Arducam IMX219 Wide Angle Camera Module, drop in replacement for Raspberry Pi V2 and Nvidia Jetson Nano Camera
- Wider Angle of View: 175°(D) wide-angle Lens, which provides a much wider view
- Replaceable Lens: Various M12 Lens for your different requirement
- <span ...
The image sensor adopted in the Raspberry Pi camera module V2 – IMX219 – is natively supported by the Jetson Nano and Xavier NX with the IMX219 camera driver shipped as the default one.
Showing 1–15 of 19 results
