Arducam Stereo Camera Package for ROS on Jetson Released
How to use this Arducam Stereo Camera Package for ROS?
In the video:
In the documentations:
Using Arducam Camarray on ROS
Depth Mapping with ROS and Jetson Nano 1.Install Driver Please refer to this page to follow the driver installation. Follow this tutorial to install ROS: Installation 3.Create ROS Workspace Follow this tutorial to create a ROS Read more…
Why are we releasing this ROS package?
What is ROS?
The Robot Operating System (ROS) is a set of software libraries and tools that help you build robot applications. From drivers to state-of-the-art algorithms, and with powerful developer tools, ROS has what you need for your next robotics project. And it’s all open source.
ROS used on Raspberry Pi and Jetson Platforms
ROS + Raspberry Pi is such a powerful combination to create smart robots, with a somehow low cost, and very small electronic board embedded in the robot.The Jetson Nano is designed for autonomous machines, it is a tiny, low power and affordable platform with a high level of computing power allowing to perform real time computer vision and mobile-level deep learning operations on the edge.
Arducam Stereo Camera Solution and ROS
The solution to the stereo camera – Arducam Camarray
Camarray is the 2nd generation of Arducam multi-camera solution which aggregates multiple camera inputs into a side-by-side style image output.The Camarray solution allows you to connect up to 4 MIPI cameras over a single MIPI CSI-2 interface, using I2C broadcasting and oscillator sharing, the output image is fully synchronized.
What are the Arducam Camarray products that can be used with this package?
The Camarray solution comes with 3 different styles: the stereo camera module, the stereo camera HAT and the Quad camera HAT.
1. Stereo Camera Module
Camarray Solution Prototypes , Cameras for RaspberryPi
Arducam 1MP*2 Stereo Camera for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Dual OV9281 Monochrome Global Shutter Camera Module
Buy Now- Supports Multiple Platforms: Compatible with Raspberry Pi and Jetson Nano/Xavier NX, also can be extended to other platforms that have MIPI CSI-2 interface and standard Video4Linux2(V4L2) driver, hence it can be used for different platforms without changing the hardware and the …
Arducam 2MP*2 Stereo Camera for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Dual OV2311 Monochrome Global Shutter Camera Module
The stereo camera module is designed for binocular applications like robots, depth sensing. It has a fixed baseline between two cameras, and a standard 15pins CSI-2 FPC cable connection to the backend processor. Camera driver and tutorial documents are available for popular embedded systems like Raspberry Pi and Jetson Nano.
2. Stereo Camera HAT
12MP IMX477 Camera for Jetson , Jetson Cameras
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Nvidia Jetson Nano and Xavier NX, Two 12.3MP IMX477 Camera Modules with CS Lens and Camarray Stereo Camera HAT
Buy Now- Work Natively with Jetson Nano and Jetson Xavier NX. NOTE: This bundle can’t work with Raspberry Pi, please check Raspberry Pi Version B0265R
- High Resolution: This bundle includes two high quality cameras, which adopts 1/2.3″ 12.3 Megapixel IMX477 sensor for sharp …
12MP IMX477 Cameras , Camarray Solution Prototypes
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi, Two 12.3MP IMX477 Camera Modules with CS Lens and Camarray Stereo Camera HAT
Buy Now- Work Natively with Raspberry Pi: This bundle runs two synchronous IMX477 cameras through a single connection with Raspberry Pi’s native high-speed MIPI CSI-2 port. Support Raspberry Pi 4, Pi 3/3B+, Pi Zero, check Jetson Nano/NX version B0265N.
- High Resolution: This bundle …
Camarray Solution Prototypes , Jetson Cameras
Arducam 1MP*2 Stereoscopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Two OV9281 Global Shutter Monochrome Camera Modules and Camarray Stereo Camera HAT
Buy Now- Supports Multiple Platforms: This bundle runs two synchronous OV9281 cameras through a single connection with MIPI CSI-2 port, compatible with Raspberry Pi and Jetson Nano/Xavier NX, also can be extended to other platforms that have MIPI CSI-2 interface and standard Video4Linux2(V4L2) …
The stereo camera HAT is an upgrade version from its ancestor, that merge two camera inputs and output the same resolution image to cheat the backend processor as if there is only one camera connected. Now it supports the new 12MP HQ camera IMX477, and keeps the same FOV as the input image by changing the output image display ratio.
3. Quad Camera HAT
Arducam 1MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Four OV9281 Global Shutter Monochrome Camera Modules and Camarray Camera HAT
Buy Now- Supports Multiple Platforms: This bundle runs four synchronous OV9281 cameras through a single connection with MIPI CSI-2 port, compatible with Raspberry Pi and Jetson Nano/Xavier NX, also can be extended to other platforms that have MIPI CSI-2 interface and standard Video4Linux2(V4L2) …
The quad camera HAT is designed for more advanced usecase which requires more cameras and synchronization. Incorporating with different color filters, the user can create multi spectrum images more easily.
What can you do with Arducam Stereo Camera and ROS?
ROS visual SLAM (Simultaneous Localization and Mapping) and avoidance is a typical usecase for the stereo camera. It can be used to know where the robot is and which direction it heads to. And camarray is an ideal solution for such an application. Arducam has both stereo camera hardware, device driver, and tutorial document for ROS on the Jetson platform, accelerating the stereo camera integration into your current robotic system.
0 Comments
