Nvidia Jetson Cameras
  3. Nvidia Jetson Cameras
  4. Multiple cameras on the Jetson
  5. Using Arducam Camarray on ROS
Depth Mapping with ROS and Jetson Nano
1.Install Driver
Please refer to this page to follow the driver installation.
NOTE
Don’t forget to test the camera to make sure your hardware connection is right.
2.Install ROS
Follow this tutorial to install ROS: Installation
3.Create ROS Workspace
Follow this tutorial to create a ROS workspace: Create a ROS Workspace
4.Dependent Installation
wget https://bootstrap.pypa.io/get-pip.py && python get-pip.py
sudo pip install v4l2
sudo apt install ros-melodic-camera-info-manager-py
step4
5.Install arducam_stereo_camera package
Copy the arducam_stereo_camera folder to the src folder of the ROS workspace:
git clone https://github.com/ArduCAM/Camarray_HAT.git
cp -r Camarray_HAT/Jetson/ROS/arducam_stereo_camera ~/catkin_ws/src
cd ~/catkin_ws/ && catkin_make
step5
6.Run Stereo Pipeline
6.1 Run Camera
You can modify the launch parameters before running the camera.
vim ~/catkin_ws/src/arducam_stereo_camera/launch/arducam_stereo_camera.launch
step6.1
NOTE
You can use the v4l2-ctl --list-formats-ext command to view the existing resolution and pixelformat
Open two terminals, one running roscore and the other running camera.
roscore #run roscore
roslaunch arducam_stereo_camera arducam_stereo_camera.launch #run camera
step6.1 1 01
6.2 Stereo Calibration
Refer to this document for stereo calibration: How to Calibrate a Stereo Camera
example:
The checkerboard size used here is 11×8, and the square size is 2cm
rosrun camera_calibration cameracalibrator.py --approximate 0.1 --size 11x8 --square 0.02 right:=/arducam/right/image_raw left:=/arducam/left/image_raw right_camera:=/arducam/right left_camera:=/arducam/left
step6.2
step6.2 1
After the calibration is complete, click commit to send the parameters to the camera node.
2020 10 17 10 22 50 00 03 07 00 03 10
6.3 Run Stereo Matching
Refer to this document for stereo matching: stereo_image_proc
example:
Open two terminals, one runs stereo_image_proc and the other runs image_view
ROS_NAMESPACE=arducam rosrun stereo_image_proc stereo_image_proc
rosrun image_view stereo_view stereo:=/arducam image:=image_rect
You can also run rqt_reconfigure to dynamically configure the parameters of stereo matching
rosrun rqt_reconfigure rqt_reconfigure
For more details, please refer to Choosing Good Stereo Parameters
Was this article helpful to you? Yes 1 No 2
