Off-The-Shelf Cameras
Our ready-made camera modules and boards are compatible with the entire portfolio of NVIDIA Jetson dev boards, including the recent Jetson AGX Orin, Jetson Orin NX and Jetson Orin Nano.
Arducam aims to make computer vision with the NVIDIA Jetson platform simpler, smarter, and more cost-effective. We help NVIDIA Jetson users to design their machine vision products from the system level right down to camera specs. Our flexible hardware gives users the freedom to create scalable, on-demand single/multiple camera solutions with any CMOS sensor, any camera interface, any lens mount, and tailored ISP tuning algorithms. Leverage Arducam’s application-driven camera building blocks and expertise to accelerate project development/camera evaluation, and professionally off-load your effort. With Arducam, you can not only save budget on the hardware part but also get any Jetson-powered end application/product to market faster.
Support for almost all CMOS image sensors ranging from 0.3MP ~ 108MP, featured with high resolution, high frame rate, extremely low light, and global shutter.
Available with DVP, MIPI, LVDS, HISPI, all of them are convertible from one to another to match your target interface/platform.
Proprietary Hardware or Software ISP solutions for AE, AWB, AF, etc. that make the image quality close to the state-of-art phone cameras. And it’s not limited to vendor-specific ISP implementations.
Closely working with leading lens suppliers, and from super wide-angle to telephoto, our solutions cover M3.5~M8, M12, CS, and C mounts.
No longer limited by the camera ports you have from the host processor, a camera multiplexer helps you switch to a camera at a time and a camera combiner that aggregates multiple camera video streams into a single video stream.
Camera extension solution helps you extend your camera board far away from your processor and go beyond the limitations of the camera’s physical interface specs.
Our CAD designers are ready to bring any of your enclosure idea into existence. From 3D printing for prototypes to CNC parts or injection molding for different production, we can help simplify the entire process.
All Arducam cameras are well tailored with C/C++, Python sample code which are OpenCV, GStreamer, and Tensorflow friendly.
NVIDIA Jetson Orin Series is the latest released high-speed development boards by NVIDIA Jetson. At present, Arducam has completed the adaptation of some cameras on NVIDIA Jetson Orin NX, and will release the new hardware version soon. The adaptation of other boards of NVIDIA Jetson Orin Series is ongoing.
Handpicked sensors, precision imaging. Versatile multi-camera flexibility. Effortless setup, instant results. Seamless Integration with AGX Orin’s ISP. Value-packed affordability.
| SKU | Sensor | Resolution | Color Filter Array | Features | Lens Mount | Lastest Tested JetPack & L4T | Supported Jetson Products |
| B0191 | IMX219 | 8MP | Bayer RGB | Mini Size | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0179 | IMX219 | 8MP | Bayer RGB | Wide Angle | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0181 | IMX219 | 8MP | Bayer RGB | Autofocus | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0183 | IMX219 | 8MP | Bayer RGB | Low Distortion | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0287 | IMX219 | 8MP | Bayer RGB | Wide Angle | Fisheye M12 Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B01678MP | IMX219 | 8MP | Bayer RGB | Pan-Tilt-Zoom | M14 Motorized Zoom Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B03961 | IMX219 | 8MP | Bayer RGB | Quad-Camera Kit | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0472 | IMX219 | 8MP | Bayer RGB | Multi-Camera Kit | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin |
| B0249 | IMX477 | 12MP | Bayer RGB | High Resolution | CS Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0250 | IMX477 | 12MP | Bayer RGB | HDMI Extension | CS Mount Lens with Case | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0273 | IMX477 | 12MP | Bayer RGB | Motorized Focus | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0274 | IMX477 | 12MP | Bayer RGB | Motorized IR-cut | CS Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0251 | IMX477 | 12MP | Bayer RGB | Mini Size | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B016712MP | IMX477 | 12MP | Bayer RGB | Pan-Tilt-Zoom | Motorized Zoom Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B03971 | IMX477 | 12MP | Bayer RGB | Quad-Camera Kit | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0265N2 | IMX477 | 12MP | Bayer RGB | Dual-Camera Kit | CS Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0473 | IMX477 | 12MP | Bayer RGB | Multi-Camera Kit | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin |
| B03881 | IMX519 | 16MP | Bayer RGB | Quad-Camera Kit | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| SKU | Sensor | Resolution | Color Filter Array | Features | Lens Mount | Lastest Tested JetPack & L4T | Supported Jetson Platforms |
| B0223 | OV9281 | 1MP | Monochrome | Global Shutter | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0221 | OV2311 | 2MP | Monochrome | Global Shutter | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0429 | AR0234 | 2MP | Bayer RGB | Global Shutter | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0371 | IMX519 | 16MP | Bayer RGB | Autofocus | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0367 | AR1820HS | 18MP | Bayer RGB | High Resolution | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0324 | IMX230 | 21MP | Bayer RGB | High Resolution | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0410 | ToF | 0.43MP | N/A | Depth Sensing | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0266 | OV9281 | 1MP | Monochrome | Dual-Camera Kit | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0267 | OV9281 | 1MP | Monochrome | Quad-Camera Kit | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0331 | OV9782 | 1MP | Bayer RGB | Quad-Camera Kit | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| B0492N | AR0234 | 2.3MP | Bayer RGB | Global Shutter | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson Orin Nano/Orin NX |
| SKU | Sensor | Resolution | Interface | Output Format | Features | Lens Mount | Lastest Tested JetPack & L4T | Supported Jetson Products |
| B0196 | IMX219 | 8MP | USB2.0 | MJPG/YUY2 | Mini Size | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0200 | IMX291 | 2MP | USB2.0 | MJPG/YUY2/H.264 | Low Light | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0438 | AR0234 | 2MP | USB2.0 | MJPG/YUY2/H.264 | Wide Angle, WDR | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0205 | OV2710 | 2MP | USB2.0 | MJPG/YUY2 | IR Light Vision | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0468 | IMX323 | 2MP | USB2.0 | MJPG/YUY2/H.264 | Low Light, Low Distortion | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0268 | IMX298 | 16MP | USB2.0 | MJPG/YUY2 | High Resolution | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0290 | IMX298 | 16MP | USB2.0 | MJPG/YUY2 | Mini Size | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0292 | IMX219 | 8MP | USB2.0 | MJPG/YUY2 | Autofocus | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0280 | IMX477 | 12MP | USB2.0 | MJPG | High Resolution | CS Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0322 | OV2311 | 2MP | USB2.0 | MJPG/YUY2 | Mono Global Shutter | Low Distortion M12 | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0332 | OV9281 | 1MP | USB2.0 | MJPG/YUY2 | Mono Global Shutter | Low Distortion M12 | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0385 | OV9782 | 1MP | USB2.0 | MJPG/YUY2 | Color Global Shutter | Low Distortion M12 | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0447 | IMX179 | 8MP | USB2.0 | MJPG/YUY2 | Autofocus | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0454 | OV5648 | 5MP | USB2.0 | MJPG/YUY2 | Wide Angle | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0448 | IMX291 | 2MP | USB2.0 | MJPG/YUY2/H.264 | Low Light, Enclosure | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0441 | OV5648 | 5MP | USB2.0 | MJPG/YUY2 | Autofocus | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0446 | IMX179 | 8MP | USB2.0 | MJPG/YUY2 | Wide Angle | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0431 | IMX219 | 8MP | USB2.0 | MJPG/YUY2 | Mini Size, Autofocus | Stock Lens with Motor | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0497 | IMX678 | 8.3MP | USB3.0 | YUY2 | 4K Ultra Low Light | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0498 | IMX585 | 8.3MP | USB3.0 | YUY2 | 4K Ultra Low Light | C Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0496 | IMX462 | 2MP | USB3.0 | YUY2 | Ultra Low Light | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0495 | AR0234 | 2.3MP | USB3.0 | YUY2 | Color Global Shutter | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0494 | 108MP | 108MP | USB3.0 | YUY2 | Ultra High Resolution | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0486 | IMX335 | 5MP | USB3.0 | YUY2 | OIS, Low Light | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0485 | IMX258 | 13MP | USB3.0 | YUY2 | OIS | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0478 | IMX586 | 48MP | USB3.0 | YUY2 | Ultra High Resolution | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0477 | IMX283 | 20MP | USB3.0 | YUY2 | Ultra HD Imaging | C Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0476 | IMX390 | 2MP | USB3.0 | YUY2 | HDR | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0475 | OV64A40 | 64MP | USB3.0 | YUY2 | Ultra High Resolution | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0474 | IMX708 | 12MP | USB3.0 | YUY2 | High Resolution | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0471 | IMX519 | 16MP | USB3.0 | YUY2 | High Resolution | Stock Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0459 | IMX477P | 12MP | USB3.0 | YUY2 | High Resolution | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
| B0499 | IMX296 | 1.58MP | USB3.0 | YUY2 | Global Shutter | M12 Mount Lens | JetPack 6.0 DP | NVIDIA Jetson AGX Orin*/Orin Nano/Orin NX |
