Jetvariety ISP (5)
Jetvariety RAW (9)
Jetson Cameras , Jetvariety Camera Modules
Arducam 2.3MP AR0234 Global Shutter Camera for NVIDIA Jetson Nano/NX and Jetson Orin NX
Buy Now- ISP Support: Arducam Jetvatiety solution for ISP function
- Global Shutter: Better captrue fast-moving objects and eliminatie the rolling artifacts
- External Triggle: Support using external triggle function with this camera
- Wide Applications: Gesture recognizition, 3D scanning, machine vision and so on
Arducam 16MP IMX298 Camera Module for Jetson Nano (Jetvariety RAW 16)
Arducam 18MP AR1820HS Color Camera Module for Jetson Nano (Jetvariety RAW 18)
Cameras for Raspberry Pi , Global Shutter Sensors
Arducam 1MP*2 Stereo Camera for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Dual OV9281 Monochrome Global Shutter Camera Module
Buy Now- Wide Compatibility: Compatible with Raspberry Pi and Jetson Nano/Xavier NX
- More Reliable: MIPI CSI connector, which outperforms better integrity, higher throughput keeps reliability even in the vibration environment
- Complete Synchronization: The frames of dual cameras is synchronized in hardware level
- Mono …
Global Shutter Sensors , Jetson Cameras
1MP*2 OV9281 Global Shutter Monochrome Stereoscopic Camera Bundle Kit for Raspberry Pi and Nvidia Jetson Nano/Xavier NX
- Mono …
Arducam 1MP*2 Wide Angle Stereo Camera for Raspberry Pi, Jetson Nano and Xavier NX, Dual OV9281 Monochrome Global Shutter Camera Module
1MP*4 Quadrascopic OV9281 Global Shutter Monochrome Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX
- Mono …
Arducam 1MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Four OV9782 Global Shutter Color Camera Modules and Camarray Camera HAT
- Complete Synchronization: The frames of every cameras is synchronized in hardware level
- Mono …
Arducam 2MP OV2311 Global Shutter M12 Mount NoIR Mono Camera Modules for NVIDIA Jetson Nano/NX and Jetson Orin NX
- Sensor: Global Shutter 2MP OV2311 Monochrome Image Sensor. Max resolution:1600×1300
- Replaceable Lens: Equipped with a replaceable M12 Lens, you can exchange the Lens fit the M12 Mount
- V4L2 Framework: Support standard V4L2 …
The Jetvariety Project aims to provide a solution to add support to the camera modules that are currently beyond the NVIDIA support. Those camera modules are either V4L2 compliant or NVIDIA Argus API compliant.
There are 3 series in this category:
1.Jetvarity RAW only acquires RAW data (V4L2)
2.Jetvarity ISP comes with discrete ISP on the camera board (V4L2)
3.Jetvariety Argus can work with Argus API and Jetson ISP
Showing 1–15 of 20 results
