Global Shutter Camera Module for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
3MP ISX031 8-Channel GMSL2 Camera Kit for NVIDIA Jetson AGX Orin – 120 dB HDR, Built-in ISP, LED Flicker Mitigation, IP67 Waterproof, up to 15 m Cable Extension
4-channel 8*Camera Bundle Kit for NVIDIA Jetson AGX Orin, 2.3MP Global Shutter Cameras, GMSL2 15m Long-Range, Sync Stereo & Onboard ISP for Robotics & Machine Vision
B0580
  • [Multi-channel] 4-channel rapid prototyping camera kits based on GMSL SerDes devices
  • [Long Range] Validated 15m coaxial cable support (1m included) for flexible long-distance connectivity.
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [Camera bundle kit] 1 set of eight cameras with pre-calibrated M12 wide-angle lens goes with the product.
  • [Sync Stereo] Hardware-synchronized stereo pair with high accuracy for precision alignment and depth.
  • [Variable Baseline] The distance between the two cameras can be physically adjusted.
$2,999.99
This stereo vision-ready kit equips with 4 sets of dual global shutter cameras (2.3MP, 1920×1200) with GMSL2 long-range support, enabling flexible deployment up to 15m via coaxial cables (1m included). Pre-calibrated with M12 wide-angle lenses and hardware-synchronized for µs-level timing accuracy, the bundle delivers motion-blur-free stereo imaging ideal for robotic depth perception, 3D inspection, or high-speed tracking. The onboard ISP provides real-time control over exposure, gain, and white balance, while the plug-and-play design accelerates proof-of-concept to mass deployment for Jetson AGX Orin platforms.
    Industrial & Robotics
  • [Humanoid] Various of humanoid robotics applications
  • [Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
  • [Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
  • [Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
  • [Pick-and-Place Systems] Real-time object tracking for automation arms
  • [Other Robotics related applications]
  • Multi-channel: supports 4 channels and 8 cameras, suitable for multi-image capture applications like robotics.
  • GMSL2 Long Range Connectivity 15m Coaxial Cable Support: Includes a 1m coaxial cable with validated support for up to 15m, allowing flexible long-distance camera placement without signal loss.
  • Global Shutter Technology: Selected Global Shutter Sensor: Captures high-quality images of fast-moving objects without motion blur, making it ideal for robotics and machine vision applications.
  • Camera Bundle Kit: Pre-Calibrated 4 sets Dual Cameras: Comes with two pre-calibrated M12 wide-angle lens cameras, ready for quick deployment in proof of concept (PoC) or mass production scenarios.
  • Sync Stereo Configuration: Hardware-Synchronized Stereo Pair: Ensures precise depth perception and alignment, crucial for applications like autonomous navigation and 3D mapping.
  • Onboard Image Signal Processing (ISP): Advanced ISP Features: Offers control over brightness, contrast, saturation, white balance, gain, and exposure, enhancing image quality for various lighting conditions.
  • Variable Baseline: In TrueSight stereo kits, the distance between the two global shutter cameras — the baseline — can be physically adjusted to suit your specific depth range and accuracy needs.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Output Format YUV
Pixel Size 3 μm × 3 μm
Sensor Active Area 1920 × 1200 pixels
Resolution&Frame Rate(Kit) 3840x1200@30fps, 2560x720@30fps, 1280x480@30fps;
FOV(DxHxV) 110°(D)×98°(H)×75°(V)
F.NO F2.4±5%
E.F.L 2.8±5% mm
Default Focus Range 0.3m to INF
TV-Distortion <-1.3%
Operating Voltage 3.3V/12V
Power Consumption Max: 30W
Camera Board Size 34mm x 34mm
Transmission Cable Power-over-Coax (PoC) compatible transceiver
GMSL Cable Length Up to 15m*
Supported Platform NVIDIA AGX Orin
Up to 15m*: Reliable 15-meter transmission mandates the use of high-quality FAKRA cables, as not all readily available cables support this range. Contact Arducam sales for qualified products if needed.
  • 8 x Arducam 2.3MP Color Global Shutter Camera Module
  • 8 x 20cm Module Extension Cable
  • 4 x Arducam Dual-Camera Adapter Board
  • 4 x Arducam GMSL2 camera Tx board
  • 1 x 4-Channel Arducam GMSL2 Rx board
  • 4 x 1m Fakra Z Female to Female RF Coaxial Cable
  • 1 x Power Supply
  • 1 x Screw Pack
    This kit supports using brackets to secure each two camera modules (the modules can still move freely horizontally). For 3D files of the brackets, check 3D Drawings in the Documentation section below. If you need ready-made brackets, please contact Arducam Sales
GMSL Camera Selection Guide
SKU Sensor Shutter Type Megapixels Resolution(WxH) Max Frame Rate Lens Options (XHFOV) Serializer ISP Support Ingress Protection
B0673 - Rolling Shutter 2MP 1920x1080 30fps 195H(Default), 120H, 100H, 60H, 30H MAX96717F On-board ISP IP67
B0674 - Global Shutter 2MP 1920x1080 30fps 195H, 120H(Default), 100H, 60H, 30H MAX96717F Built-in ISP IP67
B0573 AR0234 Global Shutter 2.3MP 1920x1200 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0611 AR0234 Global Shutter 2.3MP 3840x1200(Stereo) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0580 AR0234 Global Shutter 2.3MP 3840x1200(Stereo, 8*Camera) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0608 ISX031 Rolling Shutter 3MP 1920x1532 60fps 195H, 120H(Default), 100H, 60H, 30H MAX9295A Built-in ISP IP67
B0646 IMX900 Global Shutter 3.2MP 4080x1552(Stereo) 30fps 125H(Default), 150H, 130H, 110H MAX96717F On-board ISP -
B0549 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for RPI) 62H(Default) MAX96717F - -
B0570 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for NVIDIA) 62H(Default) MAX96717F - -
B0672 - Rolling Shutter 8.3MP 3840x2160 30fps 120H(Default), 60H, 30H MAX9295A On-board ISP IP67
B0550 IMX477 Rolling Shutter 12.3MP 4056x3040 60fps 75H(Default), 180H, 140H, 90H, 50H, 20H MAX96717F - -
B0571 IMX500 Rolling Shutter 12.3MP 4056x3040 30fps(with AI) 66H(Default), 180H, 140H, 90H, 75H, 50H, 20H MAX96717F Built-in ISP -
