This 1080p GMSL2 camera module combines high-speed Global Shutter technology with a compact 23x23mm form factor. Designed for precision motion capture, it eliminates rolling shutter artifacts (jello effect), making it indispensable for high-speed industrial and robotic applications. Equipped with an on-board ISP and 68dB HDR capability, this camera delivers clear, balanced, and distortion-free 1080p video at 30fps, even in challenging lighting and high-vibration environments.
Sports Analytics
Factory Automation
Autonomous Mobile Robots (AMR)
Logistics & Sorting
Drones & Aerospace
Global Shutter Technology: Captures the entire frame simultaneously, ensuring zero motion blur and perfect geometry for fast-moving objects.
HDR & Built-in ISP: Features 68dB High Dynamic Range and an integrated ISP to provide pre-processed, high-quality images with balanced exposure.
GMSL2 Interface: Optimized for long-distance, low-latency video transmission over coaxial cables, ensuring reliable data integrity.
Micro Form Factor: The 23x23mm miniature footprint allows for seamless integration into space-constrained robotic heads or drone gimbals.
IP67 Ruggedization: Built to withstand harsh conditions, offering full protection against dust ingress and water immersion.
Customizable Optics: Wide selection of interchangeable lenses (30H to 195H) to perfectly match your specific field-of-view requirements.
Specification
1080P
Chroma
Color
Global Shutter
Optical Format
1/2.6"
Pixel Size
3.0 µm x3.0 µm
Sensor Active Area
1920(H)×1080(V)
Sensor Image Area
5.760 mm x 3.240 mm (6.61 mm diagonal)
Resolution@fps
1920x1080@30fps
ISP
On-Board ISP
Default Lens
Focus Type
Fixed Focus
FOV
134 °(D)×120 °(H)×64 °(V)
Lens Mount
M12 Mount
F.NO
F2.2
E.F.L
3mm
IR Sensitivity
Integral 650nm IR Filter, visible light only
Max Optical Distortion
-92.20%
Alignment Method
Active Alignment (AA)
Functional and Compatibility
Camera Interface
GMSL2
Connector
FAKRA male type Z
Output Format
UYVY
HDR
68dB HDR
SNR
38dB
Serializer
MAX96717F
GMSL Cable Length
1m by default, up to 15m (please contact [email protected] for 15m cable)
Operating Voltage
8V~16V
Power Consumption
Max:1.2W
Overall Weight (Net)
50g
Overall Size
L23*W23*H31.17
Temperature range (Storage)
-40°F-203°F (-40°C to +95°C)
Temperature range (Operating)
-40°F-185°F (-40°C to +85°C)
Ingress Protection
IP67
Certification
CE & RoHS
1 x Arducam RR-GMSL2-1080P-GS-120H-IP67 Camera
1 x 1m FAKRA Coax Cable
This product does not come with a GMSL2 RX Deserializer Board by default. For specific GMSL RX platform adaptation or compatibility inquiries, please contact Arducam Sales in advance.
