USB2.0 UVC Camera Module, 2.3MP Global Shutter, with Onboard ISP for Robotics & Machine Vision
4-channel 8*Camera Bundle Kit for NVIDIA Jetson AGX Orin, 2.3MP Global Shutter Cameras, GMSL2 15m Long-Range, Sync Stereo & Onboard ISP for Robotics & Machine Vision
Global Shutter Camera Module for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
B0579
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [Onboard ISP] Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto)
  • [Jetson Optimized] Pre-validated drivers for NVIDIA Jetson Orin Nano/NX
  • [Edge AI Ready] Performance camera module for various edge AI device depolyment.
  • [High res.] 2.3MP (1920×1200) resolution delivers crisp detail for precision machine vision tasks
$139.99
This MIPI-CSI2 camera module integrates the selected global shutter sensor (2.3MP, 1920×1200) with hardware-tuned ISP pipelines, delivering exposure consistency for high-speed robotics and automated inspection. Pre-validated with Jetson Orin Nano/NX via NVIDIA’s V4L2 drivers.
    Industrial & Robotics
  • [Humanoid] Various of humanoid robotics applications
  • [Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
  • [Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
  • [Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
  • [Pick-and-Place Systems] Real-time object tracking for automation arms
  • [Other Robotics related applications]
  • Global Shutter for Fast Action Powered by the selected global shutter sensor, this camera uses a global shutter to accurately capture fast-moving scenes without motion blur—ideal for robotics, automation, and high-speed imaging.
  • Onboard ISP for Image Tuning Integrated image signal processor supports real-time control of brightness, contrast, saturation, white balance (auto/manual), gain, and exposure (auto/manual), allowing for precise image adjustments in diverse environments.
  • Jetson-Optimized Integration Comes with pre-validated drivers for NVIDIA Jetson Orin Nano and NX, enabling seamless integration and reduced setup time for AI developers and embedded system engineers.
  • Designed for Edge AI Applications Engineered for edge deployment, this camera delivers reliable performance across a wide range of AI vision applications, from object detection to smart inspection systems.
  • High-Resolution Imaging Delivers 2.3MP (1920×1200) resolution, producing crisp and detailed images for demanding machine vision and quality control tasks.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Output Format YUV
Pixel Size 3 μm × 3 μm
Sensor Active Area 1920 × 1200 pixels
Resolution&Frame Rate 1920x1200@30fps, 1280x720@30fps, 640x480@30fps
FOV(DxHxV) 110°(D)×98°(H)×75°(V)
F.NO F2.4±5%
E.F.L 2.8±5% mm
Default Focus Range 0.3m to INF
TV-Distortion <-1.3%
Operating Voltage 3.3 V
Power Consumption 1W
Camera Board Size 34mm x 34mm
Camera Interface MIPI CSI-2
Supported Platform NVIDIA Orin Nano/NX
  • 1 x Arducam 2.3MP Color Global Shutter MIPI Camera
  • 1 x 15cm 22-22pin Ribbon Cable
