This 4K GMSL2 camera module is a high-performance imaging solution designed for long-distance, low-latency applications in challenging environments. Featuring an on-board Image Signal Processing (ISP) and HDR support, the camera delivers pre-processed, high-dynamic-range 8MP video even in high-contrast lighting. Its IP67-rated rugged enclosure ensures reliable operation against dust and water, making it ideal for automotive, robotics, and industrial vision systems.
ADAS & Autonomous Driving
AMR & Delivery Robots
Industrial Inspection
Smart Agriculture
Outdoor Surveillanc
4K Ultra HD & HDR: 8MP resolution combined with High Dynamic Range (HDR) for superior detail in both highlight and shadow areas.
Advanced GMSL2 Interface: Supports high-bandwidth, low-latency video transmission over coax cables up to 15 meters.
On-Board ISP: Integrated hardware ISP handles de-Bayering, noise reduction, and color correction for ready-to-use output.
IP67 Waterproof & Dustproof: Industrial-grade sealing protects the camera from water immersion and dust ingress.
Configurable Optics: Available with multiple lens options (30°H / 60°H / Default 120°H) to suit varied field-of-view requirements.
Specification
8.3MP(4K)
Chroma
Color
Rolling Shutter
Optical Format
1/1.73"
Pixel Size
2.1 µm x2.1 µm
Sensor Active Area
3840(H)×2160(V)
Sensor Image Area
8.064 mm x 4.536 mm (9.252 mm diagonal)
Resolution@fps
3840x2160@30fps
ISP
On-Board ISP
Default Lens
Focus Type
Fixed Focus
FOV
136 °(D)×120 °(H)×65.5 °(V)
Lens Mount
M12 Mount
F.NO
F1.6
E.F.L
4.01mm
IR Sensitivity
Integral 650nm IR Filter, visible light only
Max Optical Distrotion
-58.1%
Alignment Method
Active Alignment (AA)
Functional and Compatibility
Camera Interface
GMSL2
Connector
FAKRA male type Z
Output Format
UYVY
HDR Support
Yes
LFM Support
Yes
Serializer
MAX9295A
GMSL Cable Length
1m by default, up to 15m (please contact [email protected] for 15m cable)
Operating Voltage
8V~16V
Power Consumption
Max:3W
Overall Weight (Net)
60g
Overall Size
L30*W30*H41.5
Temperature range (Storage)
-40°F-203°F (-40°C to +95°C)
Temperature range (Operating)
-40°F-185°F (-40°C to +85°C)
Ingress Protection
IP67
Certification
CE & RoHS
1 x Arducam RR-GMSL2-4K-RS-120H-IP67 Camera
1 x 1m FAKRA Coax Cable
This product does not come with a GMSL2 RX Deserializer Board by default. For specific GMSL RX platform adaptation or compatibility inquiries, please contact Arducam Sales in advance.
