Arducam GMSL2 8MP Camera Extension Kit for Raspberry Pi
Arducam GMSL2 8MP Camera Extension Kit for NVIDIA Jetson Orin Nano/Orin NX
Arducam GMSL2 12MP Camera Extension Kit for Raspberry Pi
B0550
  • [Long-distance use] Reliable imaging at distances of up to 15 meters without quality loss.
  • [GMSL2] ADI’s advanced SerDes tech delivers high bandwidth and ultra-low latency.
  • [Quality Streaming] Features an 12MP SONY IMX477 sensor for exceptional image quality.
  • [Easy and Cost-effective] Single-cable signal transmission reduces weight, power, and complexity.
  • [Backward Compatibility] Supporting GMSL1 serializers (per datasheet notes) for effortless upgrades.
  • [Versatility] Apart from automotive, it’s Ideal for robotics, surveillance, industrial automation, precision agriculture, and smart cities.
$109.99
Arducam RapidRange G2 GMSL2 camera kit is your long-distance camera solution for robotics and more.
GMSL technology, originally for automotive use, is now expanding into robotics, agriculture, smart cities, and healthcare, offering reliable, high-speed video connectivity. The Arducam RapidRange G2 camera solution maximizes GMSL2, providing an ideal long-distance camera solution to boost efficiency and innovation across industries.
The Arducam GMSL2 12MP Camera Extension Kit for Raspberry Pi delivers long-distance imaging up to 15 meters without quality loss. Powered by ADI’s SerDes technology, it offers high bandwidth and low latency. With a 12MP SONY IMX477 sensor, it ensures excellent image quality and simplifies installations with single-cable transmission. It also supports GMSL1 serializers for easy upgrades and is perfect for robotics, surveillance, automation, precision agriculture, and smart cities.
  • Robotics
  • AMR (Autonomous mobile robots)
  • Precision agriculture
  • Surveillance
  • Industrial automation
  • IoT Devices/Smart City
  • [Long-distance use]: Enjoy reliable, high-quality imaging at distances of up to 15 meters without any loss in video clarity or performance, ensuring stable transmission over extended ranges.
  • [GMSL2]: Leverages ADI's advanced SerDes technology to deliver a robust bandwidth, providing ultra-low latency and high-speed data transmission for seamless, high-performance video streaming.
  • [Quality Streaming]: Equipped with a 12MP SONY IMX477 sensor, this solution ensures exceptional image clarity and vibrant color reproduction, delivering sharp, detailed video for a variety of demanding applications.
  • [Easy and Cost-effective]: The single-cable signal transmission system simplifies installation and reduces overall system complexity by cutting down on weight, power consumption, and the need for multiple cables, offering an efficient and affordable solution.
  • [Backward Compatibility]: Supports GMSL1 serializers (as per datasheet notes), ensuring a smooth transition and effortless upgrades to the latest GMSL2 technology without requiring significant changes to your existing system setup.
  • [Versatility]: While originally designed for automotive applications, this solution is perfect for a wide range of industries, including robotics, surveillance, industrial automation, precision agriculture, and smart cities, enabling reliable, long-distance video connectivity in diverse environments.
Sensor IMX477P
Optical Size 1/2.3"
Output Format RAW12
Pixel Size 1.55 µm x 1.55 µm
Sensor Active Area 4056 x 3040 pixels
Video Modes 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120
FOV 88°(D)×75°(H)×60°(V)
Lens Mount M12
E.F.L 3.9mm
Default Focus Range 1.7m-∞
Distortion <0.3%
Operating Voltage Adapter Board: 5V/1A
Camera: 3.3V/500mA
Operating Temp. -4°F-185°F (–20℃ to +85℃)
Power Consumption 6.6w
Camera Board Size 24mm x 25mm
Transmission Cable Power-over-Coax (PoC) compatible transceiver
GMSL Cable Length Up to 15m*
Up to 15m*: Reliable 15-meter transmission mandates the use of high-quality FAKRA cables, as not all readily available cables support this range. Contact Arducam sales for qualified products if needed.
  • 1 x Arducam GMSL2 Rx board
  • 1 x Arducam GMSL2 camera Tx board
  • 1 x 1m Fakra Z Female to Female RF Coaxial Cable
  • 1 x Arducam IMX477 Camera Module
  • 1 x 40mm 22-22pin FPC Cable
  • 1 x 80mm 22-22pin FPC Cable
  • 1 x 73mm 15-22pin FFC Cable
  • 1 x Screw Pack
  • Quick Start Guide
  • GMSL Camera Selection Guide
    SKU Sensor Shutter Type Megapixels Resolution(WxH) Max Frame Rate Lens Options (XHFOV) Serializer ISP Support Ingress Protection
    B0673 - Rolling Shutter 2MP 1920x1080 30fps 195H(Default), 120H, 100H, 60H, 30H MAX96717F On-board ISP IP67
    B0674 - Global Shutter 2MP 1920x1080 30fps 195H, 120H(Default), 100H, 60H, 30H MAX96717F Built-in ISP IP67
    B0573 AR0234 Global Shutter 2.3MP 1920x1200 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
    B0611 AR0234 Global Shutter 2.3MP 3840x1200(Stereo) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
    B0580 AR0234 Global Shutter 2.3MP 3840x1200(Stereo, 8*Camera) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
    B0608 ISX031 Rolling Shutter 3MP 1920x1532 60fps 195H, 120H(Default), 100H, 60H, 30H MAX9295A Built-in ISP IP67
    B0646 IMX900 Global Shutter 3.2MP 4080x1552(Stereo) 30fps 125H(Default), 150H, 130H, 110H MAX96717F On-board ISP -
    B0549 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for RPI) 62H(Default) MAX96717F - -
    B0570 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for NVIDIA) 62H(Default) MAX96717F - -
    B0672 - Rolling Shutter 8.3MP 3840x2160 30fps 120H(Default), 60H, 30H MAX9295A On-board ISP IP67
    B0550 IMX477 Rolling Shutter 12.3MP 4056x3040 60fps 75H(Default), 180H, 140H, 90H, 50H, 20H MAX96717F - -
    B0571 IMX500 Rolling Shutter 12.3MP 4056x3040 30fps(with AI) 66H(Default), 180H, 140H, 90H, 75H, 50H, 20H MAX96717F Built-in ISP -
