Arducam RoAD.B 3MP IMX900 Color Global Shutter 125°(H) Binocular Synchronized GMSL Camera Kit
Arducam TrueSight - GMSL2 Binocular Stereo Synchronized 2.3MP Global Shutter Camera Vision Kit for Machine Vision
B0611
  • [GMSL2 Long Range] Validated 15m coaxial cable support (1m included) for flexible long-distance connectivity.
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [Camera bundle kit] Includes two pre-calibrated M12 wide-angle lens cameras ready for PoC or mass deployment.
  • [Sync Stereo] Hardware-synchronized stereo pair with high accuracy for precision alignment and depth.
  • [Onboard ISP] Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto)
  • [Fixed Baseline] Fixed 60mm Baseline to suit the distance and FOV of General-purpose machine vision needs.
$399.99
This stereo vision-ready kit pairs two selected global shutter cameras (2.3MP, 1920×1200) with GMSL2 long-range support, enabling flexible deployment up to 15m via coaxial cables (1m included). Pre-calibrated with M12 wide-angle lenses and hardware-synchronized for µs-level timing accuracy, the bundle delivers motion-blur-free stereo imaging ideal for robotic depth perception, 3D inspection, or high-speed tracking. The onboard ISP provides real-time control over exposure, gain, and white balance, while the plug-and-play design accelerates proof-of-concept to mass deployment for NVIDIA Jetson Orin series platforms.
  • Machine Vision:
    Reliable inspection powered by global-shutter stereo and low-latency GMSL transmission.
  • Motion Capture:
    Fast, precise object tracking without motion-blur for high quality imaging.
  • Virtual Reality:
    Immersive VR sensing through wide-angle dual cameras and stable stereo depth.
  • Gesture Recognition:
    Precise gesture recognition enabled by tightly synchronized stereo.
  • Depth Sensing:
    Consistent depth maps from a calibrated 55 mm baseline and dual global-shutter sensors.
  • Position Tracking:
    Stable imaging with synchronized stereo vision and high-speed GMSL connectivity.
  • 3D Scanning:
    Accurate depth capture with wide-angle synchronized stereo for detailed 3D reconstruction.
  • GMSL2 Long Range Connectivity 15m Coaxial Cable Support: Includes a 1m coaxial cable with validated support for up to 15m, allowing flexible long-distance camera placement without signal loss.
  • Global Shutter Technology Selected Global Shutter Sensor: Captures high-quality images of fast-moving objects without motion blur, making it ideal for robotics and machine vision applications.
  • Camera Bundle Kit Pre-Calibrated Dual Cameras: Comes with two pre-calibrated M12 wide-angle lens cameras, ready for quick deployment in proof of concept (PoC) or mass production scenarios.
  • Sync Stereo Configuration Hardware-Synchronized Stereo Pair: Ensures precise depth perception and alignment, crucial for applications like autonomous navigation and 3D mapping.
  • Onboard Image Signal Processing (ISP) Advanced ISP Features: Offers control over brightness, contrast, saturation, white balance, gain, and exposure, enhancing image quality for various lighting conditions.
  • Fixed Baseline In TrueSight stereo kits: the distance between the two global shutter cameras - the baseline - is fixed at 60mm to suit the distance and FOV of General-purpose machine vision needs.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Output Format YUV
Pixel Size 3 μm × 3 μm
Sensor Active Area 1920 × 1200 pixels
Resolution & Frame Rate(Kit) 3840x1200@30fps, 2560x720@30fps, 1280x480@30fps
FOV(DxHxV) 149°(D)×126°(H)×78°(V)
F.NO F2.8±5%
E.F.L 2.65±5% mm
Default Focus Range 0.5m to INF
TV-Distortion <-25.84%
Weight 6.9g (Single Lens)
Dimensions 95mm x 41mm x 29.5mm
Operating Voltage Camera: 3.3V/500mA
Power Consumption MAX:1.65W
Overall Weight (Net) 136.7g
Baseline 60mm
On Board ISP Yes
Connector (Kit) Fakra Z Type Connector
Interface GMSL2
Transmission Cable Power-over-Coax (PoC) compatible transceiver
GMSL Cable Length 1m by default, Up to 15m*
Supported OS Linux
Supported JetPack Versions JetPack6.2/L4T36.4.3 and later versions
Supported Platform NVIDIA Jetson Orin Nano/Orin NX, NVDIA Jetson AGX Orin, etc.
  • 1 x Arducam TrueSight-GMSL2 Binocular Synchronized Color Global Shutter Camera Kit
  • 1 x 1m Fakra Z Female to Female RF Coaxial Cable
  • 1 x 30cm 22-22pin FPC Cable
GMSL Camera Selection Guide
SKU Sensor Shutter Type Megapixels Resolution(WxH) Max Frame Rate Lens Options (XHFOV) Serializer ISP Support Ingress Protection
B0673 - Rolling Shutter 2MP 1920x1080 30fps 195H(Default), 120H, 100H, 60H, 30H MAX96717F On-board ISP IP67
B0674 - Global Shutter 2MP 1920x1080 30fps 195H, 120H(Default), 100H, 60H, 30H MAX96717F Built-in ISP IP67
B0573 AR0234 Global Shutter 2.3MP 1920x1200 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0611 AR0234 Global Shutter 2.3MP 3840x1200(Stereo) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0580 AR0234 Global Shutter 2.3MP 3840x1200(Stereo, 8*Camera) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0608 ISX031 Rolling Shutter 3MP 1920x1532 60fps 195H, 120H(Default), 100H, 60H, 30H MAX9295A Built-in ISP IP67
B0646 IMX900 Global Shutter 3.2MP 4080x1552(Stereo) 30fps 125H(Default), 150H, 130H, 110H MAX96717F On-board ISP -
B0549 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for RPI) 62H(Default) MAX96717F - -
B0570 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for NVIDIA) 62H(Default) MAX96717F - -
B0672 - Rolling Shutter 8.3MP 3840x2160 30fps 120H(Default), 60H, 30H MAX9295A On-board ISP IP67
B0550 IMX477 Rolling Shutter 12.3MP 4056x3040 60fps 75H(Default), 180H, 140H, 90H, 50H, 20H MAX96717F - -
B0571 IMX500 Rolling Shutter 12.3MP 4056x3040 30fps(with AI) 66H(Default), 180H, 140H, 90H, 75H, 50H, 20H MAX96717F Built-in ISP -
