Arducam TrueSight - GMSL2 Binocular Stereo Synchronized 2.3MP Global Shutter Camera Vision Kit for Machine Vision
Arducam 3.2MP IMX900 8-Channel GMSL2 Camera Kit for NVIDIA Jetson AGX Orin – Color Global Shutter Wide-angle, IP65 Waterproof, up to 8 x camera and 15 m Cable Extension
Arducam RoAD.B 3MP IMX900 Color Global Shutter 125°(H) Binocular Synchronized GMSL Camera Kit
B0646
  • [GMSL2 Long Range] Validated 15m coaxial cable support (1m included) for flexible, long-distance camera connectivity without signal degradation.
  • [Wide-Angle Vision] Features dual IMX900 sensors with 152° DFOV M12 lenses, capturing broad scenes ideal for environmental perception and navigation.
  • [Sync Stereo] Hardware-synchronized stereo pair ensures microsecond-level alignment, providing the precise RAW data foundation for host-based depth algorithms.
  • [Customization Ready] Backed by Arducam’s R&D services, enabling tailored development for onboard depth processing, ROS plugins, and specific application demos upon request.
  • [Camera Bundle Kit] Includes two pre-calibrated cameras with a fixed baseline, ready for rapid Proof of Concept (PoC) or mass production integration.
This product is currently in the trial production stage and is only available for purchase by specific customers. If you require this product, please contact Arducam Sales in advance before placing an order.
$399.99
This stereo vision-ready kit pairs two high-performance IMX900 sensors with GMSL2 long-range support, enabling flexible deployment up to 15m via coaxial cables (1m included). Equipped with 152° DFOV wide-angle M12 lenses and hardware-synchronized for µs-level timing accuracy, this bundle delivers expansive, aligned stereo imaging ideal for VSLAM, environmental perception, or host-based depth computing. Designed for flexibility, the kit outputs synchronized raw image data, empowering developers to deploy custom stereo matching algorithms across diverse edge AI platforms, including but not limited to the NVIDIA Jetson Orin series. Beyond the hardware, Arducam provides extensive customization services to tailor software solutions—ranging from onboard depth calculation and ROS plugins to turnkey demos—ensuring a perfect fit for your specific application requirements.
    These application examples are for reference only; please contact Arducam for specific details.
  • Autonomous Navigation:
    Broad environmental awareness powered by 152° wide-angle stereo vision and low-latency GMSL transmission.
  • VSLAM (Visual SLAM):
    Stable feature tracking and mapping enabled by wide-field synchronized imaging.
  • Depth Perception:
    Host-based depth map generation from a calibrated baseline and high-fidelity dual Sony sensors.
  • Robotic Obstacle Avoidance:
    Real-time hazard detection using synchronized stereo feeds processed on the edge.
  • 3D Reconstruction:
    Detailed scene capture with wide-angle optics for comprehensive 3D modeling algorithms.
  • Situational Awareness:
    Surveillance and monitoring with expansive field-of-view and high-speed GMSL connectivity.
  • AGV/AMR Guidance:
    Reliable visual input for automated guided vehicles requiring long-cable flexibility.
  • GMSL2 Long Range Connectivity 15m Coaxial Cable Support: Includes a 1m coaxial cable with validated support for up to 15m, allowing flexible long-distance camera placement on large robots or vehicles without signal loss.
  • Wide-Angle Vision 152° DFOV Optics: Equipped with 152° diagonal field-of-view M12 lenses, capturing a broader scene to enhance navigation algorithms and spatial awareness.
  • High-Fidelity Sensors IMX900 Stereo Pair: Captures clear, high-quality images with Sony’s IMX900 technology, providing the reliable data foundation needed for computer vision tasks.
  • Sync Stereo Configuration Hardware-Synchronized Stereo Pair: Ensures precise alignment between left and right channels with microsecond-level accuracy, crucial for generating accurate disparity maps on the host processor.
  • Streamlined Output Raw Data for Host Processing: Delivers synchronized image streams directly to the host (NVIDIA Jetson), giving developers complete freedom to implement custom depth and AI algorithms without onboard ISP interference.
  • Camera Bundle Kit Pre-Calibrated Dual Cameras: Comes with two pre-calibrated cameras ready for quick integration, simplifying the mechanical and software setup for stereo vision development.
  • Fixed Baseline Optimized for General Vision: The distance between the two cameras is fixed (e.g., 60mm) to suit the distance and FOV requirements of general-purpose machine vision and robotics needs.
Sensor SONY IMX900
Still Resolution 3.2 Megapixels
Shutter Type Global Shutter
Optical Size 1/3.1"
Output Format YUV
Pixel Size 2.25 μm × 2.25 μm
Sensor Active Area 2064 × 1552 pixels
Resolution & Frame Rate(Kit) 4080x1552@14fps YUV
FOV(DxHxV) 152°(D)×125°(H)×74°(V)
F.NO F2.0±5%
E.F.L 1.9±5% mm
TV-Distortion <-25%
Dimensions 95mm x 41mm x 29.5mm
Operating Voltage Camera: 3.3V/500mA
Power Consumption MAX:1.65W
Overall Weight (Net) 137g
Baseline 60mm
On Board ISP Support
Interface & Connector (Kit) GMSL2, Fakra Z Type Connector
GMSL Serializer MAX96717
GMSL Deserializer Not limited to MAX96712, MAX9295, MAX96724, etc..
Transmission Cable 1m by default, Up to 15m*
Supported OS Linux(Ubuntu)
Sync Method Hardware Synchronized
Supported Platform NVIDIA Jetson Orin Nano/Orin NX, etc.
  • 1 x Arducam RoAD.B-GMSL2 IMX900 Binocular Synchronized Color Global Shutter Camera Kit
  • 1 x Arducam GMSL2 RX Deserializer Board for NVIDIA Orin Nano/NX
  • 1 x 1m Fakra Z Female to Female RF Coaxial Cable
GMSL Camera Selection Guide
SKU Sensor Shutter Type Megapixels Resolution(WxH) Max Frame Rate Lens Options (XHFOV) Serializer ISP Support Ingress Protection
B0673 - Rolling Shutter 2MP 1920x1080 30fps 195H(Default), 120H, 100H, 60H, 30H MAX96717F On-board ISP IP67
B0674 - Global Shutter 2MP 1920x1080 30fps 195H, 120H(Default), 100H, 60H, 30H MAX96717F Built-in ISP IP67
B0573 AR0234 Global Shutter 2.3MP 1920x1200 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0611 AR0234 Global Shutter 2.3MP 3840x1200(Stereo) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0580 AR0234 Global Shutter 2.3MP 3840x1200(Stereo, 8*Camera) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0608 ISX031 Rolling Shutter 3MP 1920x1532 60fps 195H, 120H(Default), 100H, 60H, 30H MAX9295A Built-in ISP IP67
B0646 IMX900 Global Shutter 3.2MP 4080x1552(Stereo) 30fps 125H(Default), 150H, 130H, 110H MAX96717F On-board ISP -
B0549 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for RPI) 62H(Default) MAX96717F - -
B0570 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for NVIDIA) 62H(Default) MAX96717F - -
B0672 - Rolling Shutter 8.3MP 3840x2160 30fps 120H(Default), 60H, 30H MAX9295A On-board ISP IP67
B0550 IMX477 Rolling Shutter 12.3MP 4056x3040 60fps 75H(Default), 180H, 140H, 90H, 50H, 20H MAX96717F - -
B0571 IMX500 Rolling Shutter 12.3MP 4056x3040 30fps(with AI) 66H(Default), 180H, 140H, 90H, 75H, 50H, 20H MAX96717F Built-in ISP -
