This stereo vision-ready kit pairs two selected global shutter cameras (2.3MP, 1920×1200) with GMSL2 long-range support, enabling flexible deployment up to 15m via coaxial cables (1m included). Pre-calibrated with M12 wide-angle lenses and hardware-synchronized for µs-level timing accuracy, the bundle delivers motion-blur-free stereo imaging ideal for robotic depth perception, 3D inspection, or high-speed tracking. The onboard ISP provides real-time control over exposure, gain, and white balance, while the plug-and-play design accelerates proof-of-concept to mass deployment for Jetson Orin Nano/NX platforms.
Industrial & Robotics
[Humanoid] Various of humanoid robotics applications
[Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
[Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
[Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
[Pick-and-Place Systems] Real-time object tracking for automation arms
[Other Robotics related applications]
GMSL2 Long Range Connectivity
15m Coaxial Cable Support: Includes a 1m coaxial cable with validated support for up to 15m, allowing flexible long-distance camera placement without signal loss.
Global Shutter Technology
Selected Global Shutter Sensor: Captures high-quality images of fast-moving objects without motion blur, making it ideal for robotics and machine vision applications.
Camera Bundle Kit
Pre-Calibrated Dual Cameras: Comes with two pre-calibrated M12 wide-angle lens cameras, ready for quick deployment in proof of concept (PoC) or mass production scenarios.
Sync Stereo Configuration
Hardware-Synchronized Stereo Pair: Ensures precise depth perception and alignment, crucial for applications like autonomous navigation and 3D mapping.
Onboard Image Signal Processing (ISP)
Advanced ISP Features: Offers control over brightness, contrast, saturation, white balance, gain, and exposure, enhancing image quality for various lighting conditions.
Variable Baseline
In TrueSight stereo kits, the distance between the two global shutter cameras — the baseline — can be physically adjusted to suit your specific depth range and accuracy needs.
2.3MP Color Image Sensor
Still Resolution
2.3 Megapixels
Color Filter Type
Color
Global Shutter
Optical Size
1/2.6"
Output Format
YUV
Pixel Size
3 μm × 3 μm
Sensor Active Area
1920 × 1200 pixels
Resolution&Frame Rate(Kit)
3840x1200@30fps, 2560x720@30fps, 1280x480@30fps
Focus Type
Fixed Focus
FOV(DxHxV)
110°(D)×98°(H)×75°(V)
Lens Mount
M12 Mount
F.NO
F2.4±5%
E.F.L
2.8±5% mm
Default Focus Range
0.3m to INF
IR Sensitivity
Integrated 650nm IR filter
TV-Distortion
<-1.3%
Operating Voltage
Adapter Board: 5V/1A Camera: 3.3V/500mA
Operating Temp.
32°F-158°F (0°C to 70°C)
Power Consumption
MAX:6.6W
Camera Board Size
34mm x 34mm
Transmission Cable
Power-over-Coax (PoC) compatible transceiver
GMSL Cable Length
Up to 15m*
Supported Platform
NVIDIA Orin Nano/NX
Up to 15m*: Reliable 15-meter transmission mandates the use of high-quality FAKRA cables, as not all readily available cables support this range. Contact Arducam sales for qualified products if needed.
2 x Arducam 2.3MP Color Global Shutter Camera Module
2 x 20cm Module Extension Cable
1 x Arducam Dual-Camera Adapter Board
1 x Arducam GMSL2 camera Tx board
1 x Arducam GMSL2 Rx board
1 x 1m Fakra Z Female to Female RF Coaxial Cable
1 x 30cm 22-22pin FPC Cable
1 x Screw Pack
This kit supports using brackets to secure each two camera modules (the modules can still move freely horizontally). For 3D files of the brackets, check 3D Drawings in the Documentation section below. If you need ready-made brackets, please contact Arducam Sales
