Arducam RapidRange-4K HDR 120°(HFOV) Wide-Angle GMSL2 IP67 Camera Module
Arducam RapidRange 1080P Color Global Shutter 120 °(HFOV) Wide-Angle GMSL2 IP67 Camera Module
Arducam RapidRange 1080P Low Light 195 °(HFOV) Fisheye GMSL2 IP67 Camera Module
B0673
Part No
RR-GMSL2-1080P-RS-195H-IP67
  • Crisp 1080P Video: Full HD resolution at 30fps with enhanced high-sensitivity low-light performance.
  • Ultra-Wide Perspective: Default 218°(D) x 195°(H) lens for maximum situational awareness.
  • Miniature Design: Extremely small 23x23mm housing for covert or space-limited integration.
  • GMSL2 Interface: Ensures high-speed, low-latency data transmission over coaxial cables.
  • Ruggedized & Waterproof: IP67 rating ensures durability in outdoor and industrial deployments.
  • Customizable FOV: Choose from 30°H, 60°H, 100°H, 120°H, or the default 195°H lens options.
SAMPLE PRICE
$149.99
VOLUME PRICE
This ultra-compact 1080p GMSL2 camera module is engineered for high-performance imaging in space-constrained and harsh environments. Measuring only 23x23mm, it integrates a built-in ISP and a high-sensitivity sensor that excels in low-light conditions. With its IP67-rated housing and GMSL2 interface, this camera provides a robust, low-latency video solution for long-distance transmission, making it perfect for surround-view systems and industrial robotics.
  • 360° Surround View Systems
  • AMR & Delivery Robots
  • UAVs & Drones
  • Automotive Rear-View & Parking Assist
  • Industrial Endoscopy & Inspection
  • High-Sensitivity Low-Light Imaging: Optimized sensor performance ensures clear, low-noise 1080p video at 30fps in dimly lit environments.
  • Ultra-Compact Form Factor: The 23x23mm footprint allows for flexible installation in the tightest mounting positions.
  • Built-in ISP & GMSL2: Features an integrated ISP for automated image enhancement and a GMSL2 interface for reliable, long-reach connectivity.
  • Industrial-Grade Protection: Fully sealed IP67 enclosure provides complete protection against water immersion and dust.
  • Versatile Lens Ecosystem: Offers multiple FOV options ranging from narrow 30°H to ultra-wide 195°H to meet diverse application needs.
Specification
Resolution 1080P
Chroma Color
Optical Format 1/2.8"
Pixel Size 2.9 µm x 2.9 µm
Sensor Active Area 1920(H)×1080(V)
Sensor Image Area 5.568 mm x 3.132 mm (6.479 mm diagonal)
Resolution@fps 1920x1080@30fps
ISP Built-in ISP
Default Lens
Focus Type Fixed Focus
FOV 218 °(D)×195 °(H)×154 °(V)
Alignment Method Active Alignment (AA)
Functional and Compatibility
Camera Interface GMSL2
Connector FAKRA male type Z
Output Format UYVY
Serializer MAX96717F
Operating Voltage 7V~16V
Power Consumption Max:1W
Overall Weight (Net) 50g
Overall Size L23*W23*H31.17
Temperature range (Storage) -22°F-203°F (-30°C to +95°C)
Temperature range (Operating) -22°F-185°F (-30°C to +85°C)
Ingress Protection IP67
Certification CE & RoHS
  • 1 x Arducam RR-GMSL2-1080P-RS-195H-IP67 Camera
  • 1 x 1m FAKRA Coax Cable
  • This product does not come with a GMSL2 RX Deserializer Board by default. For specific GMSL RX platform adaptation or compatibility inquiries, please contact Arducam Sales in advance.
  • Datasheet-Camera Module
  • Quick Start Guide
GMSL Camera Selection Guide
SKU Sensor Shutter Type Megapixels Resolution(WxH) Max Frame Rate Lens Options (XHFOV) Serializer ISP Support Ingress Protection
B0673 - Rolling Shutter 2MP 1920x1080 30fps 195H(Default), 120H, 100H, 60H, 30H MAX96717F On-board ISP IP67
B0674 - Global Shutter 2MP 1920x1080 30fps 195H, 120H(Default), 100H, 60H, 30H MAX96717F Built-in ISP IP67
B0573 AR0234 Global Shutter 2.3MP 1920x1200 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0611 AR0234 Global Shutter 2.3MP 3840x1200(Stereo) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0580 AR0234 Global Shutter 2.3MP 3840x1200(Stereo, 8*Camera) 30fps 98H(Default), 180H, 150H, 125H, 85H MAX96717F On-board ISP -
B0608 ISX031 Rolling Shutter 3MP 1920x1532 60fps 195H, 120H(Default), 100H, 60H, 30H MAX9295A Built-in ISP IP67
B0646 IMX900 Global Shutter 3.2MP 4080x1552(Stereo) 30fps 125H(Default), 150H, 130H, 110H MAX96717F On-board ISP -
B0549 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for RPI) 62H(Default) MAX96717F - -
B0570 IMX219 Rolling Shutter 8MP 3280x2464 60fps(for NVIDIA) 62H(Default) MAX96717F - -
B0672 - Rolling Shutter 8.3MP 3840x2160 30fps 120H(Default), 60H, 30H MAX9295A On-board ISP IP67
B0550 IMX477 Rolling Shutter 12.3MP 4056x3040 60fps 75H(Default), 180H, 140H, 90H, 50H, 20H MAX96717F - -
B0571 IMX500 Rolling Shutter 12.3MP 4056x3040 30fps(with AI) 66H(Default), 180H, 140H, 90H, 75H, 50H, 20H MAX96717F Built-in ISP -
