2.3MP Global Shutter Dual-Camera Bundle Kit for NVIDIA Jetson Orin Nano/NX, GMSL2 15m Long-Range, Sync Stereo & Onboard ISP for Robotics & Machine Vision
Sync Stereo Global Shutter Dual-Camera Bundle Kit for NVIDIA Jetson Orin Nano/NX, 2.3MP High res. & Onboard ISP for Robotics & Machine Vision
2.3MP USB3.0 UVC Global Shutter Dual-Camera Bundle Kit for Robotics & Machine Vision, Stereo Depth & Onboard ISP
B0574
  • [Global Shutter] Features the selected global shutter sensor for imaging of fast-moving objects.
  • [Camera bundle kit] Includes two pre-calibrated M12 wide-angle lens cameras ready for PoC or mass deployment.
  • [Plug & Play] USB3.0 UVC, out of box use is guaranteed.
  • [Onboard ISP] Contrast, Saturation, Auto White Balance, Gain, Exposure (Manual/Auto)
  • [Sync Stereo] Hardware-synchronized stereo pair with high accuracy for precision alignment and depth.
  • [Variable Baseline] The distance between the two cameras can be physically adjusted.
$299.99
This plug-and-play stereo vision solution integrates dual selected global shutter cameras (2.3MP, 1920×1200) with USB3.0 UVC compliance, ensuring zero-driver compatibility across Windows/Linux platforms. Pre-calibrated with M12 wide-angle lenses and hardware-synchronized for precision alignment, the kit delivers motion-blur-free stereo depth for robotics navigation or precision measurement. The onboard ISP enables real-time tuning of exposure, gain, and auto white balance, while the USB3.0 interface (5Gbps bandwidth) guarantees low-latency streaming—ideal for rapid prototyping or scalable deployment in machine vision applications.
    Industrial & Robotics
  • [Humanoid] Various of humanoid robotics applications
  • [Machine Vision Inspection] Detecting defects, labels, or alignment in manufacturing lines
  • [Robotic Navigation] Visual guidance for mobile robots and AGVs (Automated Guided Vehicles)
  • [Barcode/QR Code Scanning] High-speed decoding in logistics and packaging systems
  • [Pick-and-Place Systems] Real-time object tracking for automation arms
  • [Other Robotics related applications]
  • Global Shutter Technology Selected Global Shutter Sensor: Designed for capturing high-quality images of fast-moving objects, ensuring clarity and precision in dynamic environments.
  • Camera Bundle Kit Pre-Calibrated Dual Cameras: Includes two M12 wide-angle lens cameras, ready for quick deployment in proof of concept (PoC) or mass production.
  • Plug & Play Functionality USB3.0 UVC Support: Ensures out-of-the-box usability, allowing for easy integration without extensive setup.
  • Onboard Image Signal Processing (ISP) Comprehensive ISP Controls: Features adjustments for contrast, saturation, auto white balance, gain, and exposure (both manual and automatic) to optimize image quality.
  • Sync Stereo Configuration Hardware-Synchronized Stereo Pair: Provides high accuracy for depth perception and alignment, essential for applications requiring precise 3D mapping.
  • Variable Baseline In TrueSight stereo kits, the distance between the two global shutter cameras — the baseline — can be physically adjusted to suit your specific depth range and accuracy needs.
Sensor 2.3MP Color Image Sensor
Shutter Type Global Shutter
Optical Size 1/2.6"
Pixel Size 3 µm x 3 µm
Frame Rate (USB 3.0) 3840*1200@30fps, 2560*720@30fps; 1280*480@30fps;
FOV(DxHxV) 110°(D)×98°(H)×75°(V)
F.NO F2.4±5%
E.F.L 2.8±5% mm
Default Focus Range 0.3m to INF
TV-Distortion <-1.3%
Power Requirements Max: 2W
Camera Board Size 34mm x 34mm
UVC Controls Contrast, Saturation, White Balance (Auto/Manual), Gain, Exposure (Manual/Auto)
  • 1 x Arducam 2.3MP Stereo Synchronized USB3 UVC Camera Module Kit
  • 1 x 1m USB3 Type-C cable
This kit supports using a bracket to secure two camera modules (the modules can still move freely horizontally). For 3D file of the bracket, check 3D Drawing in the Documentation section below. If you need ready-made bracket, please contact Arducam Sales.
