Arducam RapidRange 1080P Color Global Shutter 120 °(HFOV) Wide-Angle GMSL2 IP67 Camera Module
Arducam 3.2MP IMX900 8-Channel GMSL2 Camera Kit for NVIDIA Jetson AGX Orin – Color Global Shutter Wide-angle, IP65 Waterproof, up to 8 x camera and 15 m Cable Extension
Arducam RoAD.B 3MP IMX900 Pre-tuned ISP Color Global Shutter 125°(H) Binocular Synchronized GMSL Camera Kit
B0682
Part No
RR-GMSL2-3MP-GS-125H-Flagship
[Professional NVIDIA ISP] Pre-tuned for IMX900 sensors to deliver stable, high-fidelity 1920x1536@30fps imaging with superior clarity and color accuracy specifically for the Jetson Orin platform.
[Jetson Orin Native] Seamlessly compatible with NVIDIA Jetson Orin NX and Nano, providing full out-of-the-box support for JetPack 6.2.2 (L4T 36.5.0) for rapid, production-ready deployment.
[GMSL2 & Hardware Sync] Utilizes MAX96717/MAX96716 for low-latency transmission up to 15m, featuring microsecond-level hardware synchronization for precise stereo vision and depth computing.
[Wide-Angle Vision] Dual IMX900 sensors paired with 152° DFOV M12 lenses provide an expansive field of view, offering a robust and high-resolution data foundation for VSLAM and spatial AI.
[Tailored Solutions] Backed by Arducam’s customization services, enabling hardware-level lens and enclosure modifications, as well as software-level IMU integration and bespoke SDK/GUI development.
The Arducam IMX900 GMSL2 Stereo Camera Kit is a professional-grade vision solution specifically engineered for the NVIDIA Jetson Orin Nano and Orin NX platforms. Featuring dual IMX900 sensors and a pre-calibrated NVIDIA ISP (Image Signal Processor), this kit delivers exceptional image quality with superior color accuracy, and stable exposure—essential for mission-critical Robotics/AI vision tasks.
Leveraging the robust GMSL2 interface (MAX96717 serializer and MAX96716 deserializer), the system supports high-bandwidth, low-latency video transmission up to 15m via coaxial cables. The sensors are hardware-synchronized at the microsecond level, providing perfectly aligned 2048x1552 @30fps streams for precise depth computing and VSLAM. Beyond the standard kit, Arducam provides comprehensive customization services, including specialized lens selection, ruggedized enclosures, integrated IMUs, and bespoke SDK/GUI development to ensure a seamless fit for your specific deployment needs.
These application examples are for reference only; please contact Arducam for specific details.
Autonomous Mobile Robots (AMR): High-fidelity stereo vision for obstacle detection and path planning in diverse lighting environments.
VSLAM & Spatial AI: Precise feature tracking and environment mapping enabled by synchronized IMX900 imaging and NVIDIA-optimized ISP.
Industrial Automation: Reliable 2048x1552 resolution for quality inspection and automated sorting on the Jetson Orin edge.
Warehouse AGVs: Long-reach GMSL2 connectivity allows for flexible camera placement on large-scale automated guided vehicles.
Precision Agriculture: Robust perception for crop monitoring and robotic harvesting with stable, high-quality image data.
3D Scene Reconstruction: Provides a clean, synchronized data foundation for high-accuracy depth mapping and point cloud generation.
Optimized NVIDIA ISP Tuning: Features a professional, pre-calibrated ISP pipeline for the NVIDIA Jetson Orin platform, ensuring outstanding image clarity and stability right out of the box.
Seamless Jetson Orin Compatibility: Specifically designed for NVIDIA Jetson Orin NX and Orin Nano, with full support for JetPack 6.2.2 (L4T 36.5.0) for rapid integration.
High-Resolution IMX900 Stereo: Delivers dual-channel 2048x1552 @30fps video streams, offering a perfect balance between high spatial resolution and real-time performance.
Enterprise GMSL2 Infrastructure: Powered by MAX96717 serializers and MAX96716 deserializers, supporting ultra-low latency transmission over coaxial cables up to 15m.
Microsecond Hardware Synchronization: Ensures absolute temporal alignment between left and right sensors, a prerequisite for accurate stereo matching and 3D perception.
Wide Field of View: Equipped with a default high-quality 152° DFOV wide-angle M12 lenses, providing expansive environmental awareness for robotic navigation.
End-to-End Customization Services: Arducam offers full-stack customization, including optical lens adjustments, specialized enclosures, IMU integration, and tailored software/SDK development.
SONY IMX900
Still Resolution
3.2 Megapixels
Color Filter Type
Color
Global Shutter
Optical Size
1/3.1"
Output Format
YUV
Pixel Size
2.25 μm × 2.25 μm
Sensor Active Area
2048 × 1552 pixels
Frame Rate(each camera)
2048 × 1552@30fps YUV
Default Lens
Focus Type
Fixed Focus
FOV(DxHxV)
152°(D)×125°(H)×74°(V)
Lens Mount
M12 Mount
F.NO
F2.0±5%
E.F.L
1.9±5% mm
TV-Distortion
<-25%
IR Sensitivity
Integrated 650nm IR filter
ISP Support
Yes
Interface & Connector (Kit)
GMSL2, Fakra Z Type Connector
GMSL Serializer
MAX96717
GMSL Deserializer
MAX96716
Transmission Cable
1m by default, Up to 15m*
Sync Method
Hardware Synchronized
Supported JetPack Version
JetPack6.2.2/L4T36.5.0
Supported Platform
NVIDIA Jetson Orin Nano/Orin NX
Exposure Time Range
32us ~ 33000us
Gain Adjustment Range
1x ~ 15.85x
Dimensions
95mm x 41mm x 29.5mm
Operating Voltage
Camera: 3.3V/500mA
Operating Temp.
32°F-158°F (0°C to 70°C)
Power Consumption
MAX:1.65W
Overall Weight (Net)
137g
Baseline
60mm
Temperature range (Storage)
-4°F-167°F (-20°C to +75°C)
Temperature range (Operating)
32°F-122°F (0°C to +50°C)
Certification
RoHS, CE
1 x Arducam RoAD.B - IMX900 Pre-tuned ISP Binocular Synchronized Color Global Shutter GMSL2 Camera Kit
1 x Arducam GMSL2 RX Deserializer Board
1 x 1m Fakra Z Female to Female RF Coaxial Cable
Tripod is not included in the package, please check UB0224 and UB0216 for additional purchase.
