Arducam 5MP OV5647 Camera Module with CS mount Lens for Raspberry Pi 5/4/3B+/3 (NoIR)
Arducam 5MP OV5647 1080p Mini Camera Module for Raspberry Pi 5/4/3B+/3
Arducam 5MP OV5647 Camera Module with M12 Lens for Raspberry Pi 4/3/3 B+, and More
B0031
Replaceable Lens: A variety of optional M12 lens can be replaced for the camera
Focus the sharpest way – From less than an inch to infinity. Check B0176 for software auto focus/manual focus
Example projects – Shoot a waterdrop half an inch away with tuned focus; Shoot a QR code or A4 paper from the other end of the room with telephoto M12 lens; Stitch a panorama with fisheye m12 lens
Options – Get M12 lens set “Arducam LK001” for optical testing and “Arducam LK002” for minimum distortion in machine vision; Get “Arducam B0055” for m12 fisheye and “Arducam B003503” for m12 night vision. Get a lens without IR filter to make this camera IR sensitive. ( Contact Arducam for other options )
The Camera Module is a custom designed add-on for Raspberry Pi. It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it exclusively carries pixel data. The board itself is tiny, at around 36mm x 36mm highlight of our module is that the Lens is replaceable compared to official one, making it perfect for mobile or other applications where size and image quality are important. It connects to Raspberry Pi by way of a short ribbon cable. The camera is connected to the BCM2835 processor on the Pi via the CSI bus, a higher bandwidth link which carries pixel data from the camera back to the processor. This bus travels along the ribbon cable that attaches the camera board to the Pi. The sensor itself has a native resolution of 5 megapixel, and has a fixed focus lens onboard. In terms of still images, the camera is capable of 2592 x 1944 pixel static images, and also supports 1080p30, 720p60 and 640x480p60/90 video.The camera is supported by the latest Raspberry Pi OS, which support using libcamera apps to capture images.
Cellular phones,PDAs,Toys
Other battery-powered products
PC multimedia
Digital still cameras,etc.
Lens holder: M12x0.5
5MPixel sensor
Integral IR filter
Frame rate at max resolution: 30fps
Connection by flat ribbon cable to 15-pin MIPI Camera Serial Interface (CSI) connector S5 on Raspberry Pi computer board
The Camera Lens for Raspberry Pi Camera Board is HX-27227
The camera is OmniVision OV5647 sensor in a fixed-focus module with replaceable Lenes
Omnivision OV5647 sensor
Optical Size
1/4” (OV5647)
5MP 2592×1944
Frame Rates
1080p 30 fps, 720p 60fps, 480p 90fps
Focal Length
4mm
Field of View(FOV)
56°(H)
Focus Type
Manual Focus
Lens Type
M12 Lens
Dimension
36×36 mm, 4 mounting holes
Peaking Current
300mA
1 x 5 Megapixels OV5647 Sensor Camera Module
1 x 15cm 15pin FPC cable
1 x 15cm 15-22pin FPC cable
Raspberry Pi Board is not included in the package
You might need extra m12 lenses to unlock its full potential
This board is slightly larger(36cm) than the official Raspberry Pi Camera V2, so it does not fit some cases for Raspberry Pi
Be gentle while changing the lens and holders or you might damage the thread, but it’s easily fixable with a new m12 holder.
