5MP OV5647 cameras, namely the V1 camera series, are used a lot on Raspberry Pi camera applications. Unlike the V2 cameras which are encrypted on the camera board with a chip, the 5MP OV5647 cameras can be easily modified and customized by third-party manufacturers, thus you will see a lot of variations of this series.
Models in this Series
These camera modules may vary in camera board size, default lens mount, IR sensitivity, field of view and etc. But they are the same in terms of software operation.
Compact Size(Spy Camera)
Arducam OV5647 spy camera modules are tiny in size and born for applications that size matters. B006604N, B006603N, B006605, B006604, B006603 can be used on the Raspberry Pi Zero and Camera Module. B0066-02, B0066 can be used on Raspberry Pi 4/3B+/3.
SKU | Field of View | Cable Length | IR Sensitivity |
B006604N | 120°D | 20cm | NoIR |
B006603N | 72.4°D | 6cm | NoIR |
B006605 | 160°D | 6cm | Visible Light |
B006604 | 120°D | 6cm | Visible Light |
B006603 | 72.4°D | 6cm | Visible Light |
B0066-02 | 54°H x 41°V | 30cm | NoIR |
B0066 | 64°H x 48°V | 30cm | Visible Light |
V1 Size(25x24mm)
SKU | Case | Focus Type | Camera Cable | IR Sensitivity |
B0033R | × | Fixed Focus | 15cm/100cm 15pin cable | Visible Light |
B0033C | √ | Fixed Focus | 15cm 15pin cable | Visible Light |
B003301 | × | Fixed Focus | 15cm 15pin cable | NoIR |
B0033+B0087 | × | Fixed Focus | 15cm 15pin cable, 15cm 15-22pin cable | Visible Light |
B0167 | √ | Motorized Focus | 15cm 15pin cable | Visible Light |
B0033 | × | Fixed Focus | 15cm 15pin cable | Visible Light |
M12/CS Lens
SKU | Field of View | Lens Mount | IR Sensitivity |
B0151 | 85°H | M12 | Motorized IR Cut Filter |
B0035 | 85°H | M12 | NoIR |
B0055 | 194°H | M12 | Visible Light |
B0036 | 101°H | CS | NoIR |
B0031 | 56°H | M12 | Visible Light |
B003503 | 85°H | M12 | Motorized IR Cut Filter |
B0032 | 101°H | CS | Visible Light |
Common Specs
Sensor Model | OV5647 |
Active Pixels | 2592×1944 |
Resolution | 5MP |
Pixel Size | 1.4μm×1.4μm |
OV5647 Full Datasheet
Refer here:
https://www.arducam.com/downloads/modules/RaspberryPi_camera/OV5647DS.pdf
Quick Start Guide
Hardware Setup
Cable Connection
3.Insert the ribbon cable
4.Push the plastic clip down
Case Installation (optional)
Software Setup
Beginner Graphic Tutorial
Getting started with Raspberry Pi
Basic Camera Usage
Once installed, there are various ways the cameras can be used. The simplest option is to use one of the provided camera applications. There are four Linux command-line applications installed by default (e.g. raspistill
): using these is described on this page.
You can also programatically access the camera using the Python programming language, using the picamera
library.
Advanced Camera Usage
Advanced features, along with some hints and tips, are described in the following pages:
- Using RAW
- Long exposures
- Directly accessing sensors
- Using V4L2 to access the camera (e.g. Using Pi cameras as webcams)
- Removing the HQ camera IR filter
