Arducam 5MP OV5647 Camera Module with M12 Lens for Raspberry Pi 4/3/3 B+, and More
Arducam 5MP OV5647 Camera Module Motorized IR-CUT Filter for Daylight and Night vision for Raspberry Pi
Arducam 5MP OV5647 1080p Mini Camera Module for Raspberry Pi 5/4/3B+/3
B0033
  • 5MP Camera Module for RPi, fully compatible with the official ones
  • High-Definition video camera for Raspberry Pi Model A or B, B+, model 2, Raspberry Pi 3,3 B+, Pi 4, 5
  • 5MPixel sensor with a fixed-focus lens. Software autofocus lens: B0176
  • Still picture resolution: 2592 x 1944, Max video resolution: 1080p
  • USB 3.0 quick development and evaluation board for sensors like OV5647
was $13.49 Special Price $6.99
In order to meet the increasing need for Raspberry Pi compatible camera modules. The Arducam team now released another add-on mini camera module for Raspberry Pi series boards which is fully compatible with the official one.
The board itself is tiny, at around 25mm x 24mm, which makes it perfect for mobile or other applications where size and image quality are important. It connects to Raspberry Pi by way of a short ribbon cable. The camera is connected to the BCM2835/BCM2836 processor on the Pi via the CSI bus, a higher bandwidth link that carries pixel data from the camera back to the processor. This bus travels along the ribbon cable that attaches the camera board to the Pi.
The sensor itself has a native resolution of 5 megapixels and has a fixed focus lens onboard. In terms of still images, the camera is capable of 2592 x 1944 pixel static images, and also supports 1080p30, 720p60 and 640x480p60/90 video.
It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing with cameras.
  • Cellular phones, PDAs, Toys
  • PC multimedia
  • Can be used in all Raspberry Pi platforms
  • Digital still cameras,etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Field of View (FOV) 54°(H), 41°(V)
Focus Length 3.60mm
Full-frame SLR lens equivalent 35 mm
Dimension 25×24 mm
Peak Current 300mA
  • 1pcs 5MP Mini Camera OV5647 Sensor 1080p 720p video for Raspberry Pi official Board
  • 1pcs 15cm 15-15pin FPC cable
  • 1pcs 15cm 15-22pin FPC cable
  • Raspberry Pi Board is not included in the package
    Raspberry Pi 5 √ √
User guide.pdf
Note: 3D printed camera case with Raspberry Pi for CR-10, please check HERE.
New Low Cost OV5647 Mini Camera Module for Raspberry Pi Now Available
Introduction In order to meet the increasing need of Raspberry Pi compatible camera modules. The ArduCAM team now released ultra low cost add-on mini camera module for Raspberry Pi series boards which is fully compatible with official one.
1 comment
Troubleshooting
Tutorial
Selection Guide
Edit
