Arducam 5MP OV5647 Miniature Camera Module  with 300mm flex cable for Raspberry Pi 4/3B+/3
Arducam 5MP OV5647 Camera Module with M12 Lens for Raspberry Pi 4/3/3 B+, and More
Arducam 5MP OV5647 Camera Module with CS mount Lens for Raspberry Pi 5/4/3B+/3 (NoIR)
B0036
  • High-Definition video camera for Raspberry Pi Model A or B, B+, model 2, Raspberry Pi 3,3b+
  • Connection by flat ribbon cable to 15-pin MIPI Camera Serial Interface (CSI) connector S5 on Raspberry Pi computer board
  • IR Sensitivity: No integral IR filter. For IR-CUT version, check: B0032
  • Lens Mount: CS/C Mount Camera for Raspberry Pi
  • Lens options: CS/C lens can be changed on the camera module
was $34.99 Special Price $22.99
The Raspberry Pi camera module has been used for many things such as a security camera, for time-lapse photography and even sent high up into the atmosphere on a weather balloon.
With the wide range of project, Raspberry Pi’s are being used for, some users were finding that the camera was no good when it was being used in low light with an Infrared light source. Unfortunately for them, the Raspberry Pi camera module has an Infrared filter built in which makes it unusable for their project. In response, we come up with a camera module just for these type of projects called the Pi NoIR camera. It is the same as the standard camera module but without an IR filter.
Without the Infrared filter, the camera can be used for night time photography, night time security or for any project where the scene will be lit by an IR light. Without a filter, the camera sensor can see short wavelength IR light around 800nm which is the IR wavelengths not generated with heat but just beyond the visible red light in the spectrum.
The camera has the same specifications as the standard camera module but has a black circuit board so it can be told apart from the standard green camera board.
  • Night/Low Light vision
  • Wildlife research
  • Science projects
  • Night time security
  • Making artistic photo, etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
IR Sensitivity NOIR
Lens Holder CS/C Lens Holder
Focus Type Manual
Lens Type CS/C Lens
Dimension 36mm x 36mm
  • 1pcs NOIR Camera Board with LS-2717CS CS Mount Lens
  • 1pcs 15cm 15pin FPC cable
  • Raspberry Pi Board is not included in the package
  • The black board is designed as night vision version that to be distinguished with the IR-CUT version
  • For any problem or customization requirement, please directly contact [email protected]
    Raspberry Pi 5 √ √
OV5647 NoIR Camera for Raspberry Pi Now Released
  The Pi NoIR is a Raspberry Pi camera module with no Infrared filter for night time and low light photography using an Infrared light. Useful for wildlife research, science projects, night time security or making artistic photo’s. The Raspberry Pi camera module has been used for many things such as a security camera, for time […]
1 comment
You can purchase this item from Arducam distributors or Arducam's Amazon store
