1MP*2 OV9281 Global Shutter Monochrome Stereoscopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam 5MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi and Pi zero, Two 12.3MP 477P Camera Modules with CS Lens and Camarray Stereo Camera HAT
B0265R
  • Native to Raspberry Pi: No need to install additional driver for this camera bundle kit
  • High Resolution: Based on 1/2.3″ 12.3 Megapixel sensor, max still resolution 4056(H) x 3040(V)
  • Replaceable CS Lens: You can replace the default lens with other CS lens according to your demand
  • Complete Synchronization: The frames of dual cameras of this module are synchronized at the hardware level
  • Variable Baseline Extension: Compared to the fixed stereo camera module, this stereo camera bundle has higher flexibility
  • Check Jetson Nano version SKU: B0265N
$224.99
This Arducam 12MP Synchronized Stereo Camera Bundle Kit is capable of running two 12MP Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Raspberry Pi. It consists of two 12MP High Quality camera module and an Arducam stereo camarray HAT.
The camarray HAT is a multi-camera stereo synchronization solution developed by Arducam to expand the simultaneous use of multiple cameras. Through multi-camera processing technology, the clocks and data of multiple cameras can be conducted through the same i2c channel, so as to realize the synchronous use of cameras. At present, the Arducam multi-camera solution has been developed to the highest 64MP camera. This Arducam 12MP binocular camera combines two MINIcameras to obtain a wider field of view and more image processing capabilities and applications.
  • Robot navigation
  • Objective tracking
  • 3D measurement
  • 3D reconstruction
  • Depth-related vision applications, etc.
Support Platform Raspberry Pi
Output/CSI-2 Speed x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane
Output Format RAW8/RAW10/RAW12
ISP Support Supported on Raspberry Pi
External Trigger Not Support
Aggregate mode Half Spelling Combine
Frame Rate 120fps@1332x990,50fps@2028 × 1080,40fps@2028 × 1520, 10fps@4056 × 3040
Pixel Size 1.55 μm x 1.55 μm
Active Array Size 4056 x 3040
Optical Format 1/2.3”
Camera Interface 2-lane MIPI CSI-2
IR Sensitive Visible Light
Camera Board Size 38mm x 38mm
Camarray Hat Size 65 x 55 mm
Default Lens Mount CS-Mount
Hole Pitch Compatible with 29mm, 30mm, 34mm
Effective Focal Length 6mm
FOV on 1/4” RPi Camera 65° (H)
Back Focal Length 7.53mm
MOD 0.2m
F/NO Max 1.2
Lens Size 30mm x 31mm
Lens Weight 53g
  • 2 x 12.3MP color camera module mounted with CS lens
  • 1 x Arducam Camarray Stereo Camarray HAT
  • 2 x 150mm/6inch 22pin to 22pin camera cables
  • 1 x 73mm/2.87inch 15pin to 22pin camera cable
  • 1 x 80mm/3.15inch 22pin to 22pin camera cable for Pi Zero
  • 4 x M2.5*10mm Nylon Hex Standoffs
  • 4 x M2.5 Nylon Nuts
  • 4 x M2.5*6mm Nylon Screws
  • A single camera module in the bundle kit does NOT work alone with the Raspberry Pi, the Camarray HAT is required.
  • The camera bundle kit is compressed with half spelling (To ensure the same resolution after compositing, the resolution of each camera is compressed in the horizontal direction by half, but the field of view remains the same), which is different from the full spelling. It can use the official ISP, AWB, AE and other functions, the image effect is better.
  • Our main business is to assist customers in acquiring data from binocular cameras. Due to the extensive backend processing involved in depth vision, we regret that we cannot provide comprehensive operational guidance to cover all requirements. If you have relevant needs, you may refer to open-source demos for binocular cameras, such as those offered by NVIDIA.
  • The Camarray HAT is not sold alone for the following reasons:
Camarray – Arducam 12MP Synchronized Stereo Camera Bundle Kit
Introduction ​This Arducam 12MP Synchronized Stereo Camera Bundle Kit is capable of running two 12MP IMX477 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Raspberry Pi. It consists of two 12MP High-Quality IMX477 camera modules and an Arducam stereo camera HAT. The stereo camera HAT is enabled by ArduChip to disguise […]
Arducam Blog Thumbnail camarray release
13 comments
Arducam Camarray Solution Showcase:
[Tutorial] Arducam Camarray 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi
Lens Options
CS-Mount Lens
SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029
Part No
CS17320M12
CS2316ZM02
CS2308ZM05
CS2008ZM05A
CS1812ZM03
CS2325ZM01
CS1806ZM06
Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
MOD 0.30m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
Size(mm)
28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
NOTE: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
C-Mount Lens
SKU LN054 LN052 LN046 LN042 LN043 LN044 LN045 LN047
Part No
C1550ZM01
C1535ZM02
C1016ZM02
C1705ZM07
C1508ZM04
C1512ZM03
C1516ZM02
C1535ZM01
Optical Format 2/3″  2/3″ 1'' 1/1.7" 2/3" 2/3" 2/3"  2/3"
EFL(mm) 50.00  35.00 16.00 5.00 8.00 12.00 16.00 35.00
BFL(mm) 17.53  17.53 17.53 17.53 17.53 17.53 17.53 17.53
F/NO 1.8-16 1.6-16 1.4-1.6 1-1.6 1.6-16 1.6-16 1.6-16 1.7-16
HFOV on 1/2.3‘’ Cam 7° 18° 24° 65° 44° 31° 24° 10°
MOD 0.50m  0.30m 0.20m 0.15m 0.15m 0.20m 0.20m 0.20m
Size(mm)
34×40.5 50×35.5 39×50 39×41.5 39×41 34×41.5 33×36.5 35×30
C-Mount zoom Lens
SKU LN057 LN049 LN048
Part No
C2308ZM50
C20280M12
C2004ZM12
Optical Format 1/2.3″ 1/2" 1/2"
EFL(mm)
