Arducam 2MP OV2311 Global Shutter NoIR Mono Camera Module for Raspberry Pi
Arducam IMX135 MIPI 13MP Color Camera Module for Raspberry Pi 4/3B+/3
Arducam 5MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi
B0195S5MP
  • Note: This camera bundle kit is discontinued at present
  • Check Jetson Nano version SKU: B0217J5
  • This bundle includes an Arducam stereo camera HAT, a 5MP OV5647 stereo camera board, and ribbon cables to connect them.
  • The stereo camera HAT allows you to use two Raspberry Pi cameras simultaneously on a single CSI-2 slot.
  • The stereo camera board frees you of any soldering in setting up your stereo vision with two 5MP Raspberry Pi camera module.
$104.99
Now Arducam released a stereo camera HAT for Raspberry Pi which allows you to connect two 5MP OV5647 or two 8MP IMX219 pi cameras to a single standard pi board, and takes images or video at the same time, even more important they are fully synchronized. The highlight of this stereo camera HAT is that it incorporates Arducam proprietary ArduChip solution, and extends the usage of the single pi camera port, it cheats the Raspberry pi as if only one camera connected. It supports libcamera apps for preview and video capture/processing with Rpi default camera driver for its 5MP and 8MP cameras. It also supports other Arducam Raspberry Pi cameras and proprietary camera driver that works up to two 16MP. With the shared oscillator and I2C broadcasting, the two cameras are fully synchronized in the nano-second level. With the latest new coming Pi 4 hardware, Arducam makes more camera applications possible for Raspberry Pi. Combined with the stereo camera board, you are no need to modify your current Raspberry Pi V1.3 or V2 camera board with solder iron and hot air gun.
  • Support all series Raspberry Pi boards, Pi HAT board style
  • Support 1, 2 and 4 lane MIPI cameras input up-to 800Mbps/lane
  • Support 2 lane MIPI output
  • Support libcamera apps to preview and  process the video for 5MP/8MP pi cameras with half resolution combine
  • Support Arducam RPI cameras up to 16MP with proprietary camera driver with full resolution combine
  • Support digital pan in half resolution combine, programmable pan speed control HAT size: 65 x 56 mm
  • Stereo Vision
  • 360 Camera
  • Advanced Surveillance Camera
  • Enhanced Vision Goggles
  • Contact us for other platform support
Package includes
  • 1pcs Arducam Synchronized Stereo Camera HAT for Raspberry Pi
  • 1pcs 5MP Arducam Stereo Camera Board
  • 3pcs Arducam 80mm 22pin Ribbon FPC flat Wire Cable
  • 1pcs Arducam 73mm 15pin to 22pin Ribbon FPC flat Wire Cable
  • 4pcs M2.5*11mm Nylon Hex Standoffs
  • 4pcs M2.5 Nylon Nuts
  • 3pcs M2.5*6mm Nylon Screws
The Arducam Synchronized Stereo Camera HAT is designed to use two camera modules on a single Raspberry Pi board simultaneously. The model number is B0195. Read more details from the chapters below.
3D drawing.step
3D drawing.step
synchronized-stereo-pi-camera-hat-dual-blog-thumbnail
58 comments
