1MP*2 OV9281 Global Shutter Monochrome Stereoscopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam 5MP Synchronized Stereo Camera Bundle Kit for Jetson Nano
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, Two 12.3MP 477P Camera Modules with CS Lens and Camarray Stereo Camera HAT
B0265N
Check Raspberry Pi version SKU: B0265R
  • Work Natively with Jetson Board. NOTE: This bundle can’t work with Raspberry Pi, please check Raspberry Pi Version B0265R
  • High Resolution: This bundle includes two high quality cameras, which adopts 1/2.3″ 12.3 Megapixel sensor for sharp image, max. still resolution 4056(H) x 3040(V). The cameras also come with two 6mm focal length CS-Mount lenses, which equipped with a manual focus ring and an adjustable aperture ring.
  • Complete Synchronization: The frames of dual cameras of this module are synchronized at the hardware level, extra synchronization scheme by time stamping or so does not need to be considered.
  • Variable Baseline Extension: Compared to the fixed stereo camera module, this stereo camera bundle has higher flexibility, which can be used with a variable baseline device and controlled through the computer control system to achieve rapid and dynamic interactive adjustment of the moving parts for human-like multi-degree-of-freedom stereo binocular vision.
  • For the new version(R32 4.4), please refer to the following link: https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.2
  • For NVIDIA JetsonL4t 35.x Jetpack5.x and above versions , you will need the latest CamArray Kit firmware (no earlier than the 2023.02.03 version) to access it.(otherwise you can only use them on previous JetPack versions).
$224.99
This Arducam 12MP Synchronized Stereo Camera Bundle Kit is capable of running two 12MP Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on the Jetson Board. It consists of two 12MP High Quality camera module and an Arducam stereo camera HAT. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by these single-board computers. You can use this bundle to build your stereo camera system for depth-related vision applications or upgrade your IMX219 stereo setup.
⚠️ KERNEL CAMERA DRIVER USED
This camera relies on kernel drivers to work – one kernel version, one camera driver.
  1. Versions earlier than JetPack 4.3 (L4T 32.3.1) are not supported.
  2. Up or downgrading your OS leads to a kernel bump, and you’ll need to re-install a matching driver.
  3. Future JetPack/kernel updates require future drivers. When that happens, please allow us some time to process. And if you don’t see it released in time, kindly remind us.
Applications:
  • Robot navigation
  • Objective tracking
  • 3D measurement
  • 3D reconstruction
  • Depth-related vision applications
Image Sensor IMX477P
Optical Size 1/2.3"
Pixel Size 1.55 µm x 1.55 µm
Sensor Active Area 4056(H)×3040(V)
Output Format RAW8/RAW10/RAW12
Video Modes
(on NVIDIA Jetson)
L4t 32.x: 4056x3040@10fps, 2028x1529@40fps, 2028x1080@50fps
L4t 35.x: 4056×3040@10fps, 2028×1520@30fps, 2028×1080@30fps
Focus Type Manual
Focal Length 6mm
F.NO F1.2
Field of View (FOV) 65°(H)
Lens Mount CS-mount
MOD 0.2m
Working Current Max 380 mA
Camera Board Size 38 ×38 mm
Camarray Hat Size 65×56 mm
ISP Support Not Supported
External Trigger Not Supported
Aggregate mode Half Spelling Combine
Lens Options
CS-Mount Lens
SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029
Part No
CS17320M12
CS2316ZM02
CS2308ZM05
CS2008ZM05A
CS1812ZM03
CS2325ZM01
CS1806ZM06
Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
MOD 0.30m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
Size(mm)
28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
NOTE: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
C-Mount Lens
SKU LN054 LN052 LN046 LN042 LN043 LN044 LN045 LN047
Part No
C1550ZM01
C1535ZM02
C1016ZM02
C1705ZM07
C1508ZM04
C1512ZM03
C1516ZM02
C1535ZM01
Optical Format 2/3″  2/3″ 1'' 1/1.7" 2/3" 2/3" 2/3"  2/3"
EFL(mm) 50.00  35.00 16.00 5.00 8.00 12.00 16.00 35.00
BFL(mm) 17.53  17.53 17.53 17.53 17.53 17.53 17.53 17.53
F/NO 1.8-16 1.6-16 1.4-1.6 1-1.6 1.6-16 1.6-16 1.6-16 1.7-16
HFOV on 1/2.3‘’ Cam 7° 18° 24° 65° 44° 31° 24° 10°
MOD 0.50m  0.30m 0.20m 0.15m 0.15m 0.20m 0.20m 0.20m
Size(mm)
34×40.5 50×35.5 39×50 39×41.5 39×41 34×41.5 33×36.5 35×30
C-Mount zoom Lens
SKU LN057 LN049 LN048
Part No
C2308ZM50
C20280M12
C2004ZM12
Optical Format 1/2.3″ 1/2" 1/2"
EFL(mm) 8-50 2.8-12 4-12
F/NO 1.4 1-1.6 1-1.6
HFOV on 1/2.3‘’ Cam 45°-5.35° 120°-38° 80°-32°
MOD 0.20m 0.30m 0.20m
Size(mm)
40 x 68.3 44.5×58.5 33×43
Package Contents
  • 2 pcs 12.3MP color camera module mounted with CS lens
  • 1 pcs Arducam Camarray Stereo Camera HAT
  • 2 pcs 150mm/6inch 22pin to 22pin camera cables
  • 1 pcs 300mm/12inch 15pin to 22pin camera cable
  • 1 pcs 300mm/12inch 22pin to 22pin camera cable
  • 2pcs M2.5*10mm Nylon Hex Standoffs
  • 2pcs M2.5*6mm Nylon Screws
Camarray – Arducam 12MP IMX477 Synchronized Stereo Camera Bundle Kit
Introduction ​This Arducam 12MP Synchronized Stereo Camera Bundle Kit is capable of running two 12MP IMX477 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on popular embedded systems like Raspberry Pi, Jetson Nano and Jetson Xavier NX. It consists of two 12MP High Quality IMX477 camera module and an Arducam stereo camera […]
NOTE 1:
  • For connection on the NVIDIA Jetson AGX Orin platform, you will need an additional MIPI adapter board. You can contact Arducam sales to obtain one if needed.
  • The Jetson board and camera stand are not included in the package.
  • For NVIDIA JetsonL4t 35.x Jetpack5.x and above versions, you will need the latest CamArray Kit firmware (no earlier than the 2023.03.07 version) to access it.(otherwise you can only use them on previous JetPack versions).
NOTE 2:
A single camera module in the bundle kit does NOT work with the Jetson Board alone. Its connection to the Camarray HAT is required.
NOTE 3:
  • The Camarray HAT is not sold alone for the following reasons:
Customization is required if you have extra requirements as the following:
    1. You need the camera module to run on other Video Modes and Frame Rates.
    2. You need to trigger the camera with an External Hardware trigger.
    3. NOTE 4:
      • Our main business is to assist customers in acquiring data from binocular cameras. Due to the extensive backend processing involved in depth vision, we regret that we cannot provide comprehensive operational guidance to cover all requirements. If you have relevant needs, you may refer to open-source demos for binocular cameras, such as those offered by NVIDIA.
      NOTE 5:
      • This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
