Arducam Lens Calibration Tool, Field of View (FoV) Test Chart Folding Card, Pack of 2
Arducam 8MP 1080P 5-50mm Varifocal USB2.0 Camera Module, 4K Sony CMOS IMX179 UVC USB2.0 Webcam Board with 6.56ft/2m Cable for Windows, Linux, Android and Mac OS
Arducam 5MP Synchronized Stereo Camera Bundle Kit for Jetson Nano
B0217J5
Check Raspberry Pi version SKU: B0195S5MP
$99.99
As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Nano. Arducam released this Synchronized Stereo Camera Bundle Kit for Jetson Nano, which allows customers to connect two 5MP OV5647 cameras to a single Jetson Nano board, and takes images or video at the same time, even more important they are fully synchronized. The highlight of this kit is that it incorporates Arducam proprietary ArduChip solution, and extends the usage of the single Jetson Nano camera port, it cheats the board as if only one camera connected.
⚠️ KERNEL CAMERA DRIVER USED
Key Specifications:
  • Support 1, 2 and 4 lane MIPI cameras input up-to 800Mbps/lane
  • Support 2 lane MIPI output
  • Support digital pan in half resolution combine, programmable pan speed control
  • HAT size: 65 x 56 mm
Driver Features
  • Support Ardcuam Stereo Camera HAT
  • Support Standard V4L2 framework, Video Nodes, and Controls (Exposure, Gain and depending on camera parameters)
  • Single Line Driver Installation Command
  • OpenCV Friendly and Provides Source Code Demonstration
  • Stereo Vision
  • 360° Camera
  • Advanced Surveillance Camera
  • Enhanced Vision Goggles
    Camarray – Arducam 5MP OV5647 Synchronized Stereo Camera Bundle Kit
    Introduction ​This Arducam 5MP Synchronized Stereo Camera Bundle Kit is capable of running two OV5647 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on popular embedded systems like Jetson Nano and Jetson Xavier NX. It consists of two OV5647 camera modules and an Arducam stereo camera HAT. The stereo camera HAT is […]
    Jetvariety – MIPI Camera Modules for Jetson Nano/Xavier NX
    Jetson Nano’s MIPI interface and MIPI connectors The Jetson Nano Developer Kit consists of two parts: The Computer on a Module (CoM), and the carrier board. The CoM supports high-speed MIPI interface, which is now a must-have for embedded vision applications. The carrier board of the Jetson Nano developer kit exposes the MIPI interface in […]
    arducam jetson nano camera general purpose solution blog thumbnail 215 187
    Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
    16 comments
