Arducam Pivariety 18MP AR1820HS camera module for RPi 5, 4B, 3B+, 3A+, CM3/CM4, for NVIDIA® Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX
2MP Global Shutter OV2311 Mono Camera Modules Pivariety(NoIR ), compatible with Raspberry Pi ISP and Gstreamer Plugin-Arducam
Arducam MINI 5MP OV5647 Wide Angle Camera Module for Raspberry Pi 4/3/3 B+, and More
B0370
  • A variety of optional M12 lenses to meet your different needs
  • Focus in the sharpest way possible – from less than an inch to infinity. Check B0176 Software Autofocus/Manual Focus
  • Options – Get M12 lens set “Arducam LK001” for optical testing, “Arducam LK002” to minimize machine vision distortion; “Arducam B0055” for m12 fisheye and “Arducam B003503” for m12 night vision. Buy a lens without an IR filter to make this camera IR sensitive. (Contact Arducam for other options)
$29.99
The Camera Module is a custom designed add-on for Raspberry Pi. It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it exclusively carries pixel data. The camera is connected to the BCM2835 processor on the Pi via the CSI bus, a higher bandwidth link which carries pixel data from the camera back to the processor. This bus travels along the ribbon cable that attaches the camera board to the Pi.
The camera is supported by the latest version of Raspberry Pi OS, which can use libcamera apps to capture images.
  • Cellular phones,PDAs,Toys
  • PC multimedia
  • Digital still cameras,etc.
  • Lens holder: M12x0.5
  • 5MP Omnivision OV5647 sensor
  • Integral IR filter
  • Max frame rate: 30fps
  • Connection by flat ribbon cable to 15-pin MIPI Camera Serial Interface (CSI) connector S5 on Raspberry Pi computer board
  • The Camera Lens for Raspberry Pi Camera Board is LN060
  • Replaceable M12 Lens: OmniVision OV5647 sensor in a fixed-focus module with replaceable Lens
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Focal Length 1.3mm (You can screw the lens for focusing)
Horizontal Field of View (HFOV) 155°
Thread Size M12×P0.5
Dimension 25×24 mm, 4 mounting holes
Peaking Current 300mA
  • 1 x 5 Megapixels OV5647 Sensor Camera Module
  • 1 x 15cm 15pin FPC cable
  • Raspberry Pi Type B Development Board is not included
  • You might need extra m12 lenses to unlock its full potential
  • Often, focusing a lens is performed while monitoring the image quality on a video screen.
  • The Raspberry Pi motherboard is not included in the package
OV5647 Camera Module for Raspberry Pi Released
Use M12 Lenses on Raspberry Pi Camera V2 with Ease for Wide Angle, Telephoto and Macro Shooting, or Even Turn It into a Spy Camera
3Drawings https://www.uctronics.com/download/Mechanical_Drawing/B0370.STEP
