Arducam 2MP Ultra Low Light STARVIS IMX462 Motorized IR-CUT Camera for Raspberry Pi
2MP Global Shutter OV2311 Mono Camera Modules Pivariety(NoIR ), compatible with Raspberry Pi ISP and Gstreamer Plugin-Arducam
Arducam Pivariety 18MP AR1820HS camera module for RPi 5, 4B, 3B+, 3A+, CM3/CM4, for NVIDIA® Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX
B0367
  • High Resolution: 18MP AR1820HS color sensor, up to 4986 x 3684@6fps.
  • ISP Support (Raspberry Pi Only): Auto Exposure, Auto White Balance, lens shading.
  • Gstreamer support.
  • Wide Compatibility: Compatible with all libcamera-based apps maintained by the RPi foundation.
$129.99
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Lens Shading Correction, etc.
Currently, NVIDIA official has released the NVIDIA Jetson Orin series developer board. Based on it, we have also adapted Arducam Jetvariety camera into NVIDIA Jetson Orin NX kernel.
Note: This camera is released for the official NVIDIA® Jetson™ Developer Kit, and it does not guarantee to support other third-party boards.
  • Digital video cameras
  • Digital still cameras
  • Industrial camera
  • Medical camera
  • Microscopy camera
  • UAV camera
Sensor Type 18MP AR1820HS
Pixel Size 1.25um x 1.25um
Optical Size 1/2.3”
Active Pixels 4912(H)x3684(V)
Sensor Output Format RAW10
ISP Output Format JPG, YUV420, RAW, DNG; MJPEG, H.264
Interface Type 2-lane MIPI CSI-2
Video Frame Rate H.264 Max. 30fps@1920 x 1080
Frame Rates 4986 x 3684@6fps 2432 x 1840@30fps 1920 x 1080@50fps 1216 x 920@60fps
Resolution&Frame Rate(NVIDIA Orin NX) 2432 x 1840@30fps, 1920 x 1080@50fps, 1216 x 920@60fps
Focal Length 3.9mm
F.NO 2.8
FOV 75°(H)
Focus Type Manual
Board Size 40mm x 40mm
      Raspberry Pi 5 √ √
    • Due to the hardware limitations of the NVIDIA Jetson platform, this product does not support ISP functionality. If a pre-tuned ISP solution is required, please refer to Arducam xISP series or Arducam TrueSight Series
    • 1 x Arducam 18MP AR1820HS ISP Camera Module
    • 1 x 150mm 15-22pin FPC cable
    • 1 x 150mm 22-22pin FPC cable
    3D drawing.step
    3D drawing.step
    Pivariety Camera
    1. What is Pivariety? Arducam Pivariety Is a Well-Tuned ISP Camera Solution for Raspberry Pi A well-tuned hardware ISP camera solution that brings the official Pi camera experience to Moresensors with enhanced performance and works as a standard V4L2 device. Bring the RPI Offical Camera Experience to More Sensors with Enhanced Performance. Arducam Pivariety is […]
  • New: Pivariety Camera
  • Arducam Jetvariety Camera for NVIDIA Orin NX
  • Datasheet
