Arducam Pivariety 18MP AR1820HS camera module for RPi 5, 4B, 3B+, 3A+, CM3/CM4, for NVIDIA® Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX
Arducam Full HD Color Global Shutter Camera for Raspberry Pi, 2.3MP AR0234 Wide Angle Pivariety Camera Module
2MP Global Shutter OV2311 Mono Camera Modules Pivariety(NoIR ), compatible with Raspberry Pi ISP and Gstreamer Plugin-Arducam
B0381
  • Low Power Consumption: Minimize active illumination power and reduce the system power requirements.
  • More Applications: Gaze and eye-tracking capabilities, 3D image, depth sensing, etc.
  • Piavriety Solutions: Arducam Pivariety camera solution
  • Easy to Setup: Connected directly to RPi’s CSI-2 camera interface without additional hardware.
    $109.99
    Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Auto Gain Control, Lens Shading Correction, etc.
    This B0381 is a new member of Arducam Pivariety series, which adopts a 1/2.9Inch 2MP  Global Shutter sensor OV2311, assembled with a Low distortion lens. Based on OV2311 mono Global Shutter sensor, you can achieve moving capture, factory supervise, 3D image and so on.
    • Drones
    • 3D imaging
    • Machine vision
    • Industrial automation
    Image Sensor Monochrome Global Shutter OV2311
    Pixel Size 3 μm x 3 μm
    Active Array Size 1600 x 1300
    Optical Size 1/2.9 inch
    Frame Rates 1600 x 1300@30fps, 1600x 1080@30fps, 1280 x 720@60fps
    Input clock frequency 6~27 MHz
    Max S/N ratio 37.4 dB
    Dynamic range 68dB
    IR Sensitive No IR filter, sensitive to IR
    FOV on 1/4” RPi Camera 83° (H)
    Lens Mount M12
    Output interface 2-lane MIPI
    Output formats RAW 8/10 bit
    Minimum exposure time 1 row period (11.3us at the resolution of 1600x1300 on Raspberry Pi)
    • 1 x Arducam 2MP OV2311 ISP Camera Module
    • 1 x 150mm 15-22 pin 1.0mm FPC cable
    • 1 x 150mm 22-22 pin 1.0mm FPC cable
    • Raspberry Pi is not included in the package
    • You need driver for this camera module, please refer to the following documentation to run it
      Raspberry Pi 5 √ √
    How to Purchase
