Arducam High Quality Complete USB Camera Bundle, 12MP 1/2.3 Inch 477P Camera Module with 2.8-12mm Varifocal Lens C20280M12, Metal Enclosure, Tripod and USB Cable
Arducam IMX477 12MP PTZ Camera for Raspberry Pi 4/3B+/3 and Jetson Board, IR-Cut Switchable Camera with Metal Base and 2 Digital Servos
Arducam for Jetson 477P HQ Camera Board, 12.3MP Camera Board for Nvidia Jetson
B0279
was $59.99 Special Price $49.99
  • A Can't-Miss Update to IMX219 - Much better picture quality and lens flexibility, thanks to 53% more pixels, 92% larger pixel size, 192% larger imaging area, and a CS-Mount. Maximum still resolution at 4056 × 3040, frame rates: 30fps@Full 12.3MP, 60fps@1080P. NOTE:
  • Accelerated by Jetson Hardware ISP Engine - Support NVIDIA Argus Camera plugin for H264 encoding, JPEG snapshots, as well as gain, exposure, framerate, and group, hold control.
  • Only a driver away from Plug-and-Play - The Raspberry Pi HQ camera module requires hardware modification before installing the Jetson driver, which could bring potential damage and void the warranty. Ours don’t.
  • 4-Lane Camera for the Future - Route out all 4 data lanes to the camera connector for customized carrier boards with 4-lane CSI connector and future 4-lane camera driver updates.
Arducam just released this High Quality camera module for Jetson Board, an camera board with 3 hole pitches. You can use this camera module on Jetson Board natively with ISP features. No hardware modifications required, just install the driver and you are good to go.
★KERNEL CAMERA DRIVER USED
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Electrical & Mechanical
Camera Board Size 38 × 38mm
Note:For the new version(R32 4.4), please refer to the following link: https://github.com/ArduCAM/MIPI_Camera/releases
Lens Options
CS-Mount Lens
SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029
Part No
CS17320M12
CS2316ZM02
CS2308ZM05
CS2008ZM05A
CS1812ZM03
CS2325ZM01
CS1806ZM06
Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
MOD 0.30m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
Size(mm)
28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
NOTE: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
C-Mount Lens
SKU LN054 LN052 LN046 LN042 LN043 LN044 LN045 LN047
Part No
C1550ZM01
C1535ZM02
C1016ZM02
C1705ZM07
C1508ZM04
C1512ZM03
C1516ZM02
C1535ZM01
Optical Format 2/3″  2/3″ 1'' 1/1.7" 2/3" 2/3" 2/3"  2/3"
EFL(mm) 50.00  35.00 16.00 5.00 8.00 12.00 16.00 35.00
BFL(mm) 17.53  17.53 17.53 17.53 17.53 17.53 17.53 17.53
F/NO 1.8-16 1.6-16 1.4-1.6 1-1.6 1.6-16 1.6-16 1.6-16 1.7-16
HFOV on 1/2.3‘’ Cam 7° 18° 24° 65° 44° 31° 24° 10°
MOD 0.50m  0.30m 0.20m 0.15m 0.15m 0.20m 0.20m 0.20m
Size(mm)
34×40.5 50×35.5 39×50 39×41.5 39×41 34×41.5 33×36.5 35×30
C-Mount zoom Lens
SKU LN057 LN049 LN048
Part No
C2308ZM50
C20280M12
C2004ZM12
Optical Format 1/2.3″ 1/2" 1/2"
EFL(mm) 8-50 2.8-12 4-12
F/NO 1.4 1-1.6 1-1.6
HFOV on 1/2.3‘’ Cam 45°-5.35° 120°-38° 80°-32°
MOD 0.20m 0.30m 0.20m
Size(mm)
40 x 68.3 44.5×58.5 33×43
3D drawing.step
Packing contents
1pcs 12.3MP camera board with dust cap for Jetsons
1pcs 11.8"(300mm) 15pin-22pin FPC Flexible camera cable
1pcs 11.8"(300mm) 22pin-22pin FPC Flexible camera cable
