Arducam 5MP OV5647 Motorized Focus Camera Sensor for Raspberry Pi
Arducam 8MP Motorized Focus 8MP Camera IMX219 Sensor for Raspberry Pi 4/3B+/3
Arducam 18MP AR1820HS Color 1/2.3‘’ CMOS Color Rolling Shutter Camera Module for Raspberry Pi
B0164
  • Note; This camera is currently discontinued, please refer to B0367
  • Check Jetson Nano version SKU: B0216
  • More: USB 3.0 quick development?and evaluation board for sensors like AR1820HS.
$119.99
Arducam AR1820HS camera breakout incorporates ON Semiconductor 1/2.3−inch CMOS active−pixel digital imaging sensor AR1820HS with 1.25um x 1.25um A-PixHS™ BSI Pixel . It can support 18-megapixel (4912H x 3684V) digital still images at 24 fps and a 1080p plus additional 27 percent pixels for electronic image stabilization (2448H x 1378V) in digital video mode at 60 fps and 1080p120 fps.
  • Optical format 1/2.3−inch (4:3)
  • Active pixels 4912H x 3684V
  • Pixel size 1.25um x 1.25um
  • Color filter array RGB Bayer pattern
  • ADC resolution 12−bit, on−chip
  • Responsivity 0.62 V/lux−sec (545 nm)
  • Dynamic range 65.8 dB
  • SNRMAX 36.3 dB
  • Output Interface 4-Lane MIPI
  • Frame Rate 4:3 – 18 Mp full resolution at 15 fps (MIPI-4L)
  • 16:9 – 14 Mp aField of View (FOV)t 20 fps (MIPI-4L)
    16:9 – 8 Mp at 30 fps (MIPI-4L)
    16:9 – Full HD + 27.5%EIS at 60 fps
    16:9 – Full HD at 120 fps
  • Field of View (FOV): 75° (H)
  • Lens: Low distortion M12 lens (Part Number: M23390H08)
  • IR Sensitive: build-in 650nm IR filter, visible light only
  • Digital video cameras
  • Digital still cameras
  • Industrial camera
  • Medical camera
  • Microscopy camera
  • UAV camera
  • 1 pcs Arducam CMOS AR1820HS 1/2.3−inch 18MP Color Camera Module
  • 1 pcs 80mm 22pin FPC cable
  • 1 pcs 150mm 15pin to 22pin FPC cable
    NOTE: The camera module is the RAW sensor which doesn’t include ISP (Image Signal Processing) on the image sensor chip, so it only supports manual exposure, manual white balance, manual gain settings.
Lens Options
LN059
LN036
LN058
LN024
LN053
LN033
LN069
LN064
LN056 LN031 LN074
Part No:
M17350H08
M2025ZM02
M231250H03
M2306ZM13
M23390H08
M23356H09
M23270H10
M23325H12
M23272M14
M25156H18
M27150H19
Optical Format 1/2.3' 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3' 1/2.3'
EFL(mm) 35.00 25.00  12.50 6.00 3.90 3.56 2.70 3.25 2.27 1.56 1.50
BFL(mm) 5.50 5.20  2.11 7.56 4.49 5.92 4.97 4.10 3.01 4.30 5.19
Construction 5G 6G 6G+IR 6G+IR 6G+IR 4G3P+IR 5G2P+IR 7G+IR 8G+IR 6G+IR 9G+IR
F/NO 3.0 2.0  2.35 2.0 2.8 2.5 2.8 2.2 2.5 2.0 1.8
HFOV on 1/2.3‘’ Cam 8° 20° 30° 50° 75° 90° 100° 120° 140° 180° 190°
IR filter No IR filter No IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
MOD 0.35m 0.20m  0.30m 0.30m 0.30m 0.20m 0.30m 0.30m 0.20m 0.20m 0.30m
Size(mm)
22x 29.3 17 x 21 14 x 22.72 16x 16.41 14x 18.67 14x 16.3 16x 18.43 17x 19 17.2x 22 20x 17.3 24x 16.9
NOTE: The M12 Lens kit for the HQ/AR1820HS Camera module, please check LK003, 6 lenses are included.
18MP AR1820HS
Introduction Arducam AR1820HS camera breakout incorporates ON Semiconductor 1/2.3−inch CMOS active−pixel digital imaging sensor AR1820HS with 1.25um x 1.25um A-PixHS™ BSI Pixel . It can support 18-megapixel (4912H x 3684V) digital still images at 24 fps and a 1080p plus additional 27 percent pixels for electronic image stabilization (2448H x 1378V) in digital video mode […]
User guide.pdf
Arducam USB3.0 Camera Shield
Github
ArduCAM/RaspberryPi
Raspberry Pi Camera Selection Guide
Edit
B0182 8MP IMX219 replacement Autofocus 8MP RGB rolling shutter
