Note: This product was discontinued. Please check the new version-SKU: B0176.
The standard pi camera is a fixed focus lens, some of them are glued which can not be adjusted by users, and some of them are not glued which can adjust the lens focus manually. But in certain circumstances, you want to programmable control the focus distance remotely where the device can not be reached. The Arducam team now designed a motorized control focus 5MP and 8MP camera module for Raspberry Pi series boards to address this problem.
Introduction Arducam 5MP OV5647 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
The Focus Distance of a V2 Camera Module The viewing distance of the offical Raspberry Pi cameras is 1m to infinity, which means that you will extra works if you need to shoot closer than 1m. Introduction Problems with Fixed Focus In some simple applications, it’s fine to go with a fixed-focus camera. However, that’s […]
