Arducam 18MP AR1820HS Color 1/2.3‘’ CMOS  Color Rolling Shutter Camera Module for Raspberry Pi
Arducam 1MP OV9655 1/4
Arducam 1MP OV9655 1/4" CMOS Standalone Camera Module UC9655-D
Arducam 8MP Motorized Focus 8MP Camera IMX219 Sensor for Raspberry Pi 4/3B+/3
B0122
Note: This product was discontinued. Please check the new version-SKU: B0182.
$64.99
The standard pi camera is a fixed focus lens, some of them are glued which can not be adjusted by users, and some of them are not glued which can adjust the lens focus manually. But in certain circumstances, you want to programmable control the focus distance remotely where the device can not be reached. The ArduCAM team now designed a motorized control focus 5MP and 8MP camera module for Raspberry Pi series boards to address this problem.
  • High-Definition video camera for Raspberry Pi Model A/B/B+ and Raspberry Pi 2 Pi 3B, Pi 3B+ and Pi Zero
  • 8MP IMX219 sensor with motorized focus lens
  • Integral IR filter
  • Angle of View: 54 x 41 degrees
  • Field of View: 2.0 x 1.33 m at 2 m
  • Full-frame SLR lens equivalent: 35 mm
  • Focus distance: 4 cm to infinity (can be customized to much closer distance)
  • Size: 40 x 40 mm
  • 15 cm flat ribbon cable to 15-pin MIPI Camera Serial Interface (CSI) connector
  • 1pcs Motorized Focus 8MP Camera IMX219 for Raspberry Pi
  • 1pcs 15cm 15pin FPC cable
8MP IMX219 Motorized Focus Camera Module
Introduction Arducam 8MP IMX219 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
pi_camera_auto_focus_thumbnail
Solving the Raspberry Pi Camera V2 Focus Issue with An Auto-Focus Camera Module
The Focus Distance of a V2 Camera Module The viewing distance of the offical Raspberry Pi cameras is 1m to infinity, which means that you will extra works if you need to shoot closer than 1m. Introduction Problems with Fixed Focus In some simple applications, it’s fine to go with a fixed-focus camera. However, that’s […]
Selection Guide
Edit
