[Discontinued] Arducam 5MP OV5647 Wide Angle 120°(D) Miniature Camera with Flex Cable for Pi Zero and Pi Compute Module (NoIR)
Arducam 13MP MIPI Camera Module with AR1335 OBISP and M12 Mount Lens for Jetson Nano (Jetvariety ISP 13)
[Discontinued] Arducam CMOS MT9J003 1/2.3-Inch 10MP Color Camera Module Arducam 1MP OV9281 Global Shutter USB Camera Board with Low Distortion M12 Lens, Dual Microphones UVC USB2.0 Webcam Module for Computer, Laptop, Android Device and Raspberry Pi
UB0232
Discontinued, check alternative item B0332.
  • Adopts 1MP monochrome (black&white) global shutter sensor OV9281, assembled with a low distortion M12 lens which built-in an 850nm IR pass filter.
  • Global Shutter: Shoot high-speed moving objects in crisp sharp images. Avoid the rolling artifacts to get a much more accurate complete picture than the rolling shutter cameras.
  • Resolution: 1MP 1280H x 800V; Frame Rates: MJPG 120fps@1280 x 800/720P, 210fps@640 x 400/320 x 240; YUY2 10fps@1280 x 800, 30fps@640 x 360; Field of View (FOV): 100 degree (diagonal)
  • Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: The sensor’s excellent low-light sensitivity and the low distortion lens with an 850nm pass filter allow it to perform better in any application that needs gesture and eye tracking, iris and physiognomy recognition, depth and motion detection, and lunar and planetary imaging.
$44.99
Product Overview
Arducam UB0232 is a new member of the Arducam's USB camera family. It's a 1MP, based on the 1/4" monochrome global shutter OV9281 image sensor, UVC compliant, low distortion USB 2.0 camera.
The global shutter sensor's excellent low-light sensitivity and 850nm IR pass filter make it shot crisp sharp and accurate complete black and white images even for the high-speed moving objects.
APPLICATIONS
Iris and face recognition
Astrophotography
Gesture and eye tracking
Depth and motion detection
SPECS
- Sensor: 1/4” OV9281
- Resolution: 1MP 1280 x 800
- Data Format: MJPG/YUY2
- Frame Rate: MJPG 120fps@1280 x 800/720P, 210fps@640 x 400/320 x 240; YUY2 10fps@1280 x 800, 30fps@640 x 360.
- Field of View (FOV):100 degree (D)
- Lens Mount: M12
- IR Sensitivity: 850nm IR pass filter, 850nm IR light only
- Adjustable parameter: Contrast/ Saturation/ Exposure/ White balance
- System Compatibility: Win7/8/10, Linux, Mac, and OS with UVC driver
Power
- Working Current: MAX 200mA
Physical
- Dimension: 38mmx38mm (compatible with 34mmx34mm, 28x28mm)
- Cable Length: 3.3ft (1M)
Lens Options
LN001
LN002
LN003
LN004
LN005
LN006
LN007
LN008
LN009
LN010
Part No
M2016ZH01
M2508ZH02
M2506ZH04
M25360H06
M27210H08
M40180H10
M25170H12
M25156H14
M30171H16
M32076M20
Optical
Format
1/2.5''
1/2.5''
1/2.5''
1/2.5''
1/2.7''
1/4'
 1/2.5''
1/2.5''
1/3''
1/3.2''
EFL(mm)
16.00
8.00
 6.00
3.60
2.10
1.80
1.70
1.56
1.71
0.76
BFL(mm)
7.10
8.10
 7.30
5.00
6.30
4.90
4.70
4.30
4.71
2.00
Construction
6G+IR
6G+IR
6G+IR
6G+IR
6G+IR
6G+IR
 6G+IR
 6G+IR
5G+IR
2G4P+IR
F/NO
2.0
2.0
 2.0
2.0
2.0
2.4
2.0
2.0
2.2
2.1
HFOV on 1/4‘’ Cam
10°
26°
33°
67°
73°
100°
118°
141°
180°
220°
IR filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
MOD
0.3m
0.30m
 0.30m
0.20m
0.30m
0.20m
 0.20m
0.20m
 0.20m
0.20m
Size(mm)
14x16.2
14x16.9
14x17.4
14x16.8
14x15.2
14x14.5
20x18.7
20x17.3
15x19.7
16x13.5
Low Distortion Lens Options
LN011
LN012
LN015
LN013
LN014
Part No
M2504ZH05S
M25360H06S
M40320M06S
M27280M07S
M40210M09S
Optical Format
1/2.5''
1/2.5''
1/2.5''
1/2.5''
1/2.7''
EFL(mm)
4.00
3.60
 3.20
2.80
2.10
BFL(mm)
3.24
2.75
 1.60
2.60
1.19
Construction
2G2P+IR
2G2P+IR
5E+IR
2G2P+IR
2G2P+IR
F/NO
2.8
3.0
 2.0
2.8
2.2
HFOV on 1/4‘’ Cam
45°
55°
65°
70°
