Arducam for Raspberry Pi AI Camera Kit, IMX500 All-in-one Pivistation 5 AI Camera Kit
Arducam 13MP MIPI Camera Module with AR1335 OBISP and M12 Mount Lens for Jetson Nano (Jetvariety ISP 13)
B0277
  • Note: This camera module is currently discontinued
$49.99
Arducam 13MP OBISP MIPI camera features onboard ISP (Image Signal Processor), it uses standard 15pin MIPI CSI-2 interface, and works seamlessly on Jetson Nano.
⚠️ KERNEL CAMERA DRIVER USED
  • Cellular phones
  • Digital still cameras
  • PC cameras
  • IoT cameras
  • Resolution: High Resolution
  • Shutter Type: Rolling Shutter
  • Color Type: Color
  • IR Sensitivity: 650nm IR filter, visible light only.
  • Output Interface: 2-Lane MIPI CSI-2
  • Output Format: YUV422, RGB888
  • ISP Features: AWB, AE, Flip, Mirror, DeNoise, Gamma, Sharpness, Saturation, Contrast Digital Zoom, Digital Pan/Tilt, Speical Effects etc
  • Platform Support:   Jetson Nano or platform with MIPI CSI-2 interface
Specs
  • Sensor Type: 13MP AR1335
  • Pixel Size: 1.1um x 1.1um
  • Resolution: 4160x3120
  • Optical Size: 1/3"
  • Lens Spec: M12 Low distortion lens, EFL: 4.73mm, FoV(H): 50°, F/NO:2.2
  • Max Data Rate: 1.2Gbps/laneFrame Rate: 7fps@4160x3120, 11fps@3264x2448/3840x2160, 24fps@2560x1440, 30fps@1600x1200/1920x1080/640x480/320x240
  • Responsivity: 4.7k e/lux-sec
  • SNR(Max): 37dB
  • Dynamic Range: 69dB
  • Power Consumption: 270mW
  • Temperature Range: -10 ~ 70 degrees
  • Camera Driver: V4L2 Compliant driver for Jetson Nano
  • Board Size: 38mm x 38mm
  • Powerline Frequency:  50Hz, fixed
  • 1pcs Arducam 13MP OBISP Camera Module with M12 Mount Lens
  • 1pcs 15pin to 22pin ribbon cable
User guide.pdf
pi_camera_auto_focus_thumbnail
Solving the Raspberry Pi Camera V2 Focus Issue with An Auto-Focus Camera Module
The Focus Distance of a V2 Camera Module The viewing distance of the offical Raspberry Pi cameras is 1m to infinity, which means that you will extra works if you need to shoot closer than 1m. Introduction Problems with Fixed Focus In some simple applications, it’s fine to go with a fixed-focus camera. However, that’s […]
GitHub
[GitHub链接]-->
How to Purchase
Arducam OBISP MIPI Camara Module
