[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi With Fisheye Lens
[Discontinued] Arducam CMOS MT9J003 1/2.3-Inch 10MP Color Camera Module Arducam 1MP OV9281 Global Shutter USB Camera Board with Low Distortion M12 Lens, Dual Microphones UVC USB2.0 Webcam Module for Computer, Laptop, Android Device and Raspberry Pi
[Discontinued] Arducam 5MP OV5647 Wide Angle 120°(D) Miniature Camera with Flex Cable for Pi Zero and Pi Compute Module (NoIR)
B006604N
  • Supports raspberry pi zero only. For Raspberry Pi Model A/B/B+, Raspberry Pi 2/3/3B+, please search “B0066”
  • Sensor: 1/4 inch OV5647 sensor in a fixed-focus lens, angle of view: 120° diagonal
  • without IR filter
  • Still picture resolution: 2592 x 1944, Max video resolution: 1080p
  • Dimension: 200mm × 11.5mm × 5.5mm
$19.99
In order to meet the increasing need of Raspberry Pi Zero compatible camera modules, the Arducam team now released another add-on spy camera module which is fully compatible with Raspberry Pi Zero and Pi compute module.
The board itself is tiny, at around 60mm x 11.5mm. The neck width of the camera module is 6mm, this highlight making it perfect for endoscope, spy surveillance or other applications where size and image quality are important. It connects to Raspberry Pi Zero by way of a short ribbon cable. The camera is connected to the BCM2835 processor on the Pi Zero via the CSI bus, which travels along the ribbon cable that attaches the camera board to the Pi.
It attaches to Raspberry Pi Zero by way of the small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it exclusively carries pixel data.
  • Cellular phones,PDAs,Toys
  • Spy camera
  • PC multimedia
  • Digital still cameras,etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
Diagnoal Field of View (DFOV) 120°
Focus Type Fixed
Lens Type Stock Lens
Dimension 200mm × 11.5mm x 5.5mm
  • 1x camera board with a 20cm flexible cable
  • Raspberry pi zero is not included in the package
Compatibilites
RASPBERRY PI MODEL COMPATIBILITY
ONLY Support Pi Zero
OS COMPATIBILITY
  • Raspbian,
  • MotionEyeOS,
  • OctoPi,
  • Ubuntu,
  • Arch Linux, etc.
EXTENSION CABLE COMPATIBILITY
  • All 15pin Pi cam flex ribbon cables,
  • [B0107+B0087] Pi Zero cable set,
  • [B0177] Complete Pi camera cable set
MULTI-CAMERA ADAPTER COMPATIBILITY
  • [B0166] Dual-camera multiplexer,
  • [B0120] Quad-camera multiplexer,
  • [B0195] Synchronized Stereo Camera HAT
You can purchase this item from Arducam distributors or Arducam’s Amazon store
Selection Guide
Edit
