Arducam landing page ezBOX picture 2
Arducam landing page ezBOX picture 2026 1
Arducam ezBOX Series
Quick PoC, Easy Deployment, Dual Form Factors. Not ANOTHER Webcam.
Struggling with embedded vision selection and mechanical integration?
Meet Arducam ezBOX.
Simplify your evaluation process and accelerate your time to market with our plug-and-play, cost-effective UVC solutions—offering High Frame Rates (Swift), HDR (HDR), and High Resolution (Klarity), now available in both Standard and space-saving ezBOX-Slim designs tailored for all your embedded vision projects.
Why Arducam ezBOX?
🔵PAIN POINT 1
Frustrating Hardware Search: Finding the right camera modules, lenses, and configurations for specific optical needs is time-consuming.
⚪Arducam ezBOX
Diverse Performance Profiles: Choose from a focused family of SKUs designed around core visual requirements: Swift (High Frame Rate), HDR (High Dynamic Range), and Klarity (High Resolution).
🔵PAIN POINT 2
Tight Space & Mounting Limitations: Traditional square camera boxes often cannot fit into narrow device enclosures, kiosks, edge display borders, or robotic arms.
⚪Arducam ezBOX
Dual Form Factors (Standard & Slim): Available in both classic Standard Square Box for flexible mounting and ultra-narrow ezBOX-Slim for tight, space-constrained integrations.
🔵PAIN POINT 3
Complex Setup: Learning, compiling drivers, and tuning configurations can cause integration delays.
⚪Arducam ezBOX
No Drivers Required: Universal UVC (USB Video Class) compliance ensures plug-and-play simplicity across Windows, Linux, Android, and macOS without extra software headaches.
🔵PAIN POINT 4
High Costs: Traditional vision evaluation often involves expensive trial-and-error hardware purchases and custom mechanical design.
⚪Arducam ezBOX
Cost-Effective & PoC-Ready: Affordable, fully-enclosed solutions with standardized mountings and 3D CAD models available for instant structural evaluation.
🔵PAIN POINT 5
Lack of Long-term Supply and Support: Many users face supply disruptions and inadequate technical after-sales support for long-cycle projects.
⚪Arducam ezBOX
Long-term Supply & Support: Backed by Arducam’s long-term supply commitment, direct engineering support, and ongoing hardware/firmware stability for OEM and B2B deployments.
Explore the ezBOX Family
Tailored to Your Vision Needs & Physical Spaces.
The ezBOX series brings together three core performance profiles: ezBOX-Swift (High Frame Rate), ezBOX-HDR (High Dynamic Range), and ezBOX-Klarity (High Resolution). Each profile is now available in two distinct form factors—classic Standard Box and ultra-compact ezBOX-Slim—giving you full flexibility to fit both your visual requirements and mechanical constraints.
Engineered for Seamless Integration & Reliable Vision
Built with flexible form factors, universal compliance, and fine-tuned ISP controls for fast OEM deployment.
Pillar 1: Flexible Enclosure & Mechanical Design
Available in classic cubic Standard Box (36×36×17mm) and ultra-narrow ezBOX-Slim bar (65×12×10.5mm) to accommodate space-constrained kiosks, display borders, and tight robotic joints.
Robust Industrial Housing:
Crafted from durable aluminum alloy with built-in thermal management, providing structural protection and efficient heat dissipation for demanding environments.
Versatile Mounting Options:
Precision M2/M3 screw holes and tripod mounts ensure secure, vibration-resistant installation without alignment drift.
Pillar 2: Universal System Compatibility
Plug-n-Play Simplicity:
USB 2.0 UVC compliance allows true driverless setup—simply connect and start capturing without installing proprietary software.
Broad Multi-OS Support:
Native driver compatibility across Linux, Windows, macOS, and Android platforms for seamless embedded integration.
Pillar 3: Optics & On-Board ISP Controls
Precision Autofocus System:
High-speed AF system with wide 78° DFOV and large F1.8 aperture for sharp imaging from close-ups to long distance.
Proprietary ISP Controls:
Full control over imaging parameters via standard UVC controls, including Brightness, Contrast, Saturation, Auto/Manual White Balance, Gain, Exposure, and Focus.
Locate your needs
Arducam landing page ezBOX picture 2026 2
Here’s how it works: start by identifying the resolution and frame rate your application demands. With resolutions from VGA to 16MP and frame rates pushing up to 800 FPS with Global Shutter, you can easily locate the right performance profile.
ezBOX – Swift
Smooth, High-Frame-Rate Imaging
Designed for fast-moving targets and real-time vision processing. Delivers high frame rates with zero motion blur, ensuring crisp detail capture for inspection, sorting, and high-speed motion tracking.
arducam lp ezbox product portofolio ezBOX Swift
ezBOX – HDR
Exceptional Clarity in Challenging Light
Engineered for complex lighting conditions with severe glare or deep shadows. Built-in ultra-high dynamic range technology prevents overexposure and preserves key details in dynamic outdoor or industrial environments.
arducam lp ezbox product portofolio ezBOX HDR 1
ezBOX – Klarity
Crystal-Clear High-Resolution Detail
Focused on extreme clarity and high-definition detail. Features up to 4K resolution options, rich color rendition, and Digital Pan-Tilt-Zoom (ePTZ) capabilities for precise monitoring and quality inspection.
arducam lp ezbox product portofolio ezBOX Klarity 1
ezBOX GS (Global Shutter Series)
Distortion-Free High-Speed Motion, Integrated IMU & Hardware Sync
Engineered for machine vision, robotics, and precise measurement. Delivers distortion-free imaging up to 800 FPS, now upgraded with built-in IMU motion sensing and dedicated hardware trigger options.
Arducam landing page ezBOX picture 2026 9
ezBOX-GS (Standard Box): VGA Mono | Up to 800 FPS | Wide FOV | 6-Axis IMU | Ext. Trigger
View the product
Arducam landing page ezBOX picture 2026 10
ezBOX-GS (Standard Box): VGA Color | Up to 160 FPS | Wide FOV
View the product
Arducam landing page ezBOX picture 2026 11
ezBOX-GS (Standard Box): VGA Mono | Up to 800 FPS | Standard FOV | 6-Axis IMU | Ext. Trigger
View the product
ezBOX product specifications
Find the Perfect ezBOX Product for Your Project Needs
Off-the-shelf Options
Didn’t Find the Right Fit for Your Project?
OEM/ODM
We understand that every project is unique, and sometimes off-the-shelf solutions don’t quite
meet your specific needs. That’s why ezBOX offers OEM/ODM services—to help you create a
customized solution that’s tailor-made for your application.Whether you’re evaluating a concept,
building a proof of concept (POC), or scaling a fully customized product, we’re here to bring
your vision to life.
