Global Shutter USB2 UVC Camera, Ultra High FPS, VGA Monochrome, Wide Angle, Arducam ezBOX GS
Arducam 12MP 4K@25fps USB2.0 UVC Wide Angle Camera Module for Windows, Linux, and Android
Global Shutter USB2 UVC Camera, Ultra High FPS, VGA Monochrome, Arducam ezBOX GS
B0634
  • [Global Shutter Mono] VGA monochrome sensor for high-precision imaging
  • [Ultra High FPS] Up to 800 FPS at QQVGA resolution
  • [Standard FOV] Balanced field of view for accurate measurement
  • [Onboard ISP] Integrated ISP for efficient image processing
  • [Plug & Play UVC] USB2 UVC compliant, easy integration
  • [Industrial Control] Customization options for External Trigger, ROI, Fstrobe, etc., available
$19.99
The Arducam ezBOX GS B0634 is a compact monochrome global shutter USB camera optimized for precision high-speed imaging. Supporting frame rates up to 800 FPS at QQVGA resolution, it enables detailed capture of fast motion while maintaining consistent exposure across the frame. With a standard field-of-view lens, integrated onboard ISP, UVC plug-and-play support, and customizable external trigger capability, B0634 is ideal for measurement, inspection, and controlled machine vision applications.
  • High-Speed Motion Analysis
  • Machine Vision & Industrial Inspection
  • Robotics & Automation
  • Scientific & Laboratory Imaging
  • Trigger-Based Image Acquisition Systems
  • Embedded Vision & System Prototyping
  • [Global Shutter Mono] Features a VGA monochrome global shutter sensor that ensures pixel-level exposure consistency, ideal for precision measurement and motion analysis.
  • [Ultra High FPS] Supports frame rates of up to 800 FPS at QQVGA resolution, enabling capture of rapid events that are not observable with conventional USB cameras.
  • [Standard FOV] Uses a standard field-of-view lens to provide a balanced perspective, well-suited for metrology, inspection, and controlled imaging setups.
  • [Onboard ISP] Incorporates an onboard ISP to process image data in real time, delivering stable output while reducing system integration complexity.
  • [Plug & Play UVC] Designed around the USB2 UVC standard, allowing immediate use across Windows, Linux, and macOS platforms without additional drivers.
  • [Industrial Control] Housed in a durable metal enclosure, while customization options such as External Trigger, ROI, and Fstrobe are available upon request.
Product Series ezBOX-VGA GS
Max Still Resolution VGA
Color Filter Type Monochrome
Shutter Type Global Shutter
Optical Size 1/7.5″
Output Format MJPG/YUV
Pixel Size 3 µm x 3 µm
Sensor Active Area 640(H) x 480(V)
Frame Rate(MJPG) 640x480@200fps, 320x240@400fps; 160x120@800fps
Frame Rate(YUV) 640x480@60fps, 320x320@160fps; 160x120@400fps
FOV 81°(D)x69°(H)x55°(V)
USB Features
Interface USB 2.0 Device
Connector B4B-ZR JST
Operating Voltage 5V
Power Consumption 0.8W
Camera Board Size 32mmX32mmX1.6mm
Minimum Exposure Time 100µs*
External Trigger Mode Support Customization
Fstrobe Support Customization
UVC Controls Brightness, Contrast, Sharpness, PowerLine Freq, Backlight Compensation, Low Light Compensation, Gain, Exposure(Auto/Manual).
  • 1 x Arducam ezBOX VGA GS MONO USB2 UVC Camera Module
  • Due to the limitation of USB2.0 device descriptor, the software can only report a maximum frame rate of 240fps, but the camera can actually reach 800fps (the actual frame rate can be seen during preview).
  • This module supports customized resolution, frame rate, and ROI, etc.
  • This module supports a minimum exposure time of 100µs under the current UVC protocol. For even lower exposure times, please contact Arducam for customization.
