Global Shutter USB2 UVC Camera, Ultra High FPS, VGA Color, Wide Angle, Arducam ezBOX GS
B0633
  • [Global Shutter Color] VGA color sensor with accurate motion capture
  • [Ultra High FPS] Up to 160 FPS at QQVGA resolution
  • [Wide Angle Optics] Large field of view for wide-area imaging
  • [Onboard ISP] Integrated ISP for real-time image processing
  • [Plug & Play UVC] USB2 UVC standard, driver-free operation
  • [Industrial Control] Customization options for External Trigger, ROI, Fstrobe, etc., available.
$29.99
The Arducam ezBOX GS B0633 is a color global shutter USB camera built for applications that require both high-speed performance and accurate color imaging. Capable of reaching up to 160 FPS at QQVGA resolution, it captures rapid events with minimal motion distortion, while the wide-angle optics provide broad scene coverage. Featuring an onboard ISP, UVC plug-and-play operation, and a durable metal housing, B0633 is well-suited for robotics, automation, and visual inspection systems.
  • High-Speed Motion Analysis
  • Machine Vision & Industrial Inspection
  • Robotics & Automation
  • Scientific & Laboratory Imaging
  • Trigger-Based Image Acquisition Systems
  • Embedded Vision & System Prototyping
  • [Global Shutter Color] Integrates a VGA color global shutter sensor, delivering accurate color reproduction while eliminating motion distortion in high-speed scenes.
  • [Ultra High FPS] Capable of capturing images at up to 160 FPS at QQVGA resolution, ideal for fast event recording, automation, and robotic vision applications.
  • [Wide Angle Optics] The wide-angle lens enables broader scene coverage, reducing blind spots and minimizing the need for multiple cameras.
  • [Onboard ISP] Built-in ISP performs real-time color processing and image optimization, providing stable and consistent output without relying on host-side processing.
  • [Plug & Play UVC] USB2 UVC compliance ensures seamless compatibility with mainstream operating systems and vision software, with no driver installation required.
  • [Industrial Control] Housed in a durable metal enclosure, while customization options such as External Trigger, ROI, and Fstrobe are available upon request.
Product Series ezBOX-VGA GS
Max Still Resolution VGA
Shutter Type Global Shutter
Optical Size 1/7.5″
Output Format MJPG/YUV
Pixel Size 3 µm x 3 µm
Sensor Active Area 640(H) x 480(V)
Frame Rate(MJPG) 640x480@120fps, 320x240@160fps; 160x120@160fps
Frame Rate(YUV) 640x480@60fps,320x240@100fps; 160x120@100fps
FOV 166°(D)x130°(H)x100°(H)
USB Features
Interface USB 2.0 Device
Connector B4B-ZR JST
Operating Voltage 5V
Power Consumption 0.8W
Camera Board Size 32mmX32mmX1.6mm
External Trigger Function Support Customization
Fstrobe Support Customization
UVC Controls Brightness, Contrast, Sharpness, PowerLine Freq, Backlight Compensation, Gain, Exposure(Auto/Manual).
  • 1 x Arducam ezBOX VGA GS Color WA USB2 UVC Camera Module
  • This module supports customized resolution, frame rate, and ROI, etc.
  • This module supports a minimum exposure time of 100µs under the current UVC protocol. For even lower exposure times, please contact Arducam for customization.
