The Arducam ezBOX-Slim 4K HDR Camera Module is a versatile, ready-to-use addition to the ezBOX line of enclosed USB cameras. Designed for effortless setup, the Slim series replaces traditional square housing with an elongated CNC aluminum enclosure, maximizing heat dissipation and enabling seamless embedding into narrow slots. Combining 4K Ultra HD resolution and HDR with fast autofocus, it captures crisp visuals across challenging lighting conditions. Complete with driverless UVC plug-and-play convenience and flexible customization options like IMU integration, it provides a reliable, easy-to-integrate imaging solution for interactive and commercial systems.
Video Conferencing Systems: Fits discreetly onto slim monitor bezels and conference bars for high-definition meetings.
Fitness Equipment & Smart Mirrors: Integrates seamlessly into narrow frames of workout machines to enable AI pose tracking.
Liveness Detection & Kiosks: Delivers secure face verification and anti-spoofing imaging in slim self-service terminals.
Compact Embedded Vision: Ideal for smart retail displays, medical equipment, and space-critical indoor devices.
[4K HDR & Fast Autofocus] Combines 3840x2160 ultra-high resolution with High Dynamic Range and fast motorized focus, capturing vivid, balanced, and razor-sharp visuals under dynamic lighting conditions.
[Thermally Efficient CNC Housing] The high-grade aluminum CNC metal enclosure functions as an effective heat sink, ensuring optimal thermal performance and continuous operational stability under heavy workloads.
[Versatile & Flexible Integration] Engineered with an elongated slim profile and standardized mounting points, allowing engineers to effortlessly embed the camera into narrow bezels, tight slots, and compact devices.
[Seamless UVC Plug-and-Play] Built on standard UVC specifications over USB 2.0, requiring no extra drivers for instant compatibility with Windows, Linux, Android, and macOS platforms.
[Tailored OEM Customization] Supports broad custom tweaks for volume integrators, including specialized optical lenses, flexible cable lengths, custom enclosure colors, and hardware expansions like onboard IMU integration.
HDR*, Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
Operating Voltage
5V
Power Consumption
1W
Overall Size
62mm x 9mm x 6.5mm
Overall Weight (Net)
27g
Temperature range (Storage)
-4°F-167°F (-20°C to +75°C)
Temperature range (Operating)
32°F-122°F (0°C to +50°C)
Certifications
RoHS, CE
1 x Arducam ezBOX-Slim 4K HDR Autofocus USB2 UVC Camera Module
1 x 1m USB2 to B5B-ZR JST Cable
This module supports customized resolution, frame rate, and ROI, etc.
This module supports a minimum exposure time of 100µs under the current UVC protocol. For even lower exposure times, please contact Arducam for customization.
