4K HDR AutoFocus USB2.0 UVC Camera, Arducam ezBOX-HDR
High Framerate AutoFocus USB2.0 UVC Camera, Up to 360FPS, 1080P, Arducam ezBOX-Swift
B0559
  • [360 FPS at VGA Resolution] Capture fast-moving objects with exceptional clarity.
  • [Versatile FPS-Res Combinations] 9 options, from 1920x1080@100fps to 640x480@360fps, meeting diverse imaging needs.
  • [USB 2.0 UVC Compliance] Plug-and-play, no additional drivers needed.
  • [Autofocus Lens] Ensures sharp focus for every shot.
  • [Proprietary ISP] Full control over brightness, contrast, saturation, white balance, gain, focus, and exposure.
$79.99
ezBOX-Swift combines speed and precision, delivering up to 360 FPS at VGA resolution for capturing fast-moving objects with exceptional clarity. Powered by a SONY 1080P Color Sensor, it supports a wide range of FPS-Res combinations, from 1920x1080@100fps to 640x480@360fps, ensuring versatility and high-quality imaging for dynamic applications.
  • Robotics
  • Precision Agriculture
  • Motion Analysis
  • Sports Tracking
  • Industrial Automation
  • Traffic Monitoring and Surveillance
  • We Welcome You to Test: Explore the ezBOX-Swift in your own applications and share your results with us—or contact us for custom orders tailored to your specific needs!
  • ezBOX-Swift: Speed and Precision for Dynamic Applications
  • Exceptional Frame Rates Across Resolutions: The ezBOX-Swift delivers unparalleled speed, offering 9 versatile FPS-Res combinations, from 1920x1080@100fps to 640x480@360fps. This flexibility ensures smooth and precise capture of fast-moving objects, making it ideal for applications like motion analysis, sports tracking, and high-speed imaging.
  • SONY 1080P Color Sensor with Advanced Imaging: Equipped with a SONY 1080P color sensor, the Swift ensures high-quality imaging even in fast-paced scenarios. Its advanced sensor technology minimizes noise and maximizes clarity, delivering sharp and detailed visuals for dynamic applications.
  • Proprietary ISP for Full Control: The Swift features a proprietary Image Signal Processor (ISP) that provides complete control over key imaging parameters, including brightness, contrast, saturation, white balance, gain, focus, and exposure. This level of customization ensures optimal image quality tailored to specific needs, enhancing its versatility across diverse use cases.
Sensor SONY 1080P Color Sensor
Still Resolution 1080P
Optical Size 1/2.8″
Output Format MJPG
Pixel Size 2.24 µm x 2.24 µm
Sensor Active Area 1920(H) x 1080(V)
Frame Rate 1920x1080@100fps, 1280x720@180fps, 640x480@360fps*
Focus Type Autofocus
FOV 78°(D)×65°(H)×52°(V)
Lens Mount Stock Lens
F.NO F1.8
E.F.L 3.95mm
Default Focus Range 10cm-∞
Interface USB 2.0 Device
Connector B4B-ZR JST
Operating Voltage 5V
Power Consumption 1.75W
Camera Board Size 32mmX32mmX1.6mm
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
640x480@360fps*: Due to the limitation of USB2.0 device descriptor, the software can only report a maximum frame rate of 240fps, but the camera can actually reach 360fps(the actual frame rate can be seen during preview).
This camera prioritizes high frame rates. At higher frame rates, exposure time is shorter, which may affect image brightness. For best results in low-light conditions, additional lighting is recommended.
  • 1 x 1080P High Frame Rate Color USB2 UVC Camera
