[Discontinued] Arducam 2MP OV2311 Global Shutter Mono NoIR Camera Module for Jetson Nano (Jetvariety RAW 2 STK)
[Discontinued] Arducam 5MP OV5647 Camera Module with IR Cut and LED for Jetson Nano (Jetvariety RAW 5)
[Discontinued] Arducam 18MP AR1820HS Color Camera Module for Jetson Nano (Jetvariety RAW 18)
B0216
Discontinued, check the new version B0367.
  • High Resolution
  • Platform Support: Jetson Nano
  • Support RAW8/10 bayer format
  • Support standard V4L2 framework, Video Nodes and Controls (Exposure, Gain and depending on camera parameters)
  • Support Single Line Driver Installation Command
  • Support OpenCV Friendly and Provides Source Code Demonstration
$129.99
As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Nano. Arducam released this 18MP AR1820HS camera module for Jetson Nano. It incorporates ON Semiconductor 1/2.3−inch CMOS active−pixel digital imaging sensor AR1820HS with 1.25um x 1.25um A-PixHS™ BSI Pixel and can support 18-megapixel (4912H x 3684V) digital still images at 24 fps and a 1080p plus additional 27 percent pixels for electronic image stabilization (2448H x 1378V) in digital video mode at 60 fps and 1080p120 fps.
⚠️ KERNEL CAMERA DRIVER USED
Features:
  • Sensor Type: AR1820
    Pixel Size: 1.25um x 1.25um
    Optical Size: 1/2.3−inch (4:3)
    Active Pixels: 4912H x 3684V
    Color Filter Array: RGB Bayer pattern
    Field of View (FOV):75° (H)
  • Lens: low distorion M12 lens (Part Number: M23390H08)
  • ADC Resolution: 12−bit, on−chip
  • Frame Rate: 6.4fps@4896x3684/2432x1842/1920x1080  (MIPI-2L), 41fps@1216x920, 103fps@640x480
  • Interface Type: 2-Lane MIPI
  • Output Format: RAW8/RAW10 output
  • Board Size: 40x40mm
Driver Features:
  • Support RAW8/10 bayer format.
  • Support Standard V4L2 framework, Video Nodes and Controls (Exposure, Gain and depending on camera parameters)
Application:
  • Digital video cameras
  • Digital still cameras
  • Industrial camera
  • Medical camera
  • Microscopy camera
  • UAV camera
Jetvariety – MIPI Camera Modules for Jetson Nano/Xavier NX
Jetson Nano’s MIPI interface and MIPI connectors The Jetson Nano Developer Kit consists of two parts: The Computer on a Module (CoM), and the carrier board. The CoM supports high-speed MIPI interface, which is now a must-have for embedded vision applications. The carrier board of the Jetson Nano developer kit exposes the MIPI interface in […]
arducam jetson nano camera general purpose solution blog thumbnail 215 187
Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
16 comments
Lens Options
LN059
LN036
LN058
LN024
LN053
LN033
LN069
LN064
LN056 LN031 LN074
Part No:
M17350H08
M2025ZM02
M231250H03
M2306ZM13
M23390H08
M23356H09
M23270H10
M23325H12
M23272M14
M25156H18
M27150H19
Optical Format 1/2.3' 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3' 1/2.3'
EFL(mm) 35.00 25.00  12.50 6.00 3.90 3.56 2.70 3.25 2.27 1.56 1.50
BFL(mm) 5.50 5.20  2.11 7.56 4.49 5.92 4.97 4.10 3.01 4.30 5.19
Construction 5G 6G 6G+IR 6G+IR 6G+IR 4G3P+IR 5G2P+IR 7G+IR 8G+IR 6G+IR 9G+IR
F/NO 3.0 2.0  2.35 2.0 2.8 2.5 2.8 2.2 2.5 2.0 1.8
HFOV on 1/2.3‘’ Cam 20° 30° 50° 75° 90° 100° 120° 140° 180° 190°
IR filter No IR filter No IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
MOD 0.35m 0.20m  0.30m 0.30m 0.30m 0.20m 0.30m 0.30m 0.20m 0.20m 0.30m
Size(mm)
22x 29.3 17 x 21 14 x 22.72 16x 16.41 14x 18.67 14x 16.3 16x 18.43 17x 19 17.2x 22 20x 17.3 24x 16.9
NOTE: The M12 Lens kit for the HQ/AR1820HS Camera module, please check LK003, 6 lenses are included.
