Discontinued, Check Jetson Cameras
Check Raspberry Pi version SKU: B003503
As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Nano. Arducam released this OV5647 camera module for Jetson Nano. It is designed for both daylight and night vision photography with build-in IR cut filter and two infrared LED illuminator boards. The IR cut filter and the infrared LEDs are automatically ON/OFF according to the light condition and it can be widely used in wild life photography, agriculture NDVI applications and etc.
Jetson Nano’s MIPI interface and MIPI connectors The Jetson Nano Developer Kit consists of two parts: The Computer on a Module (CoM), and the carrier board. The CoM supports high-speed MIPI interface, which is now a must-have for embedded vision applications. The carrier board of the Jetson Nano developer kit exposes the MIPI interface in […]
Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
