Arducam 1MP OV9782 Global shutter color MIPI camera module 20pin for DepthAI OAK-FFC-3P-OG
[Discontinued] Arducam 5MP OV5647 Wide Angle 120°(D) Miniature Camera with Flex Cable for Pi Zero and Pi Compute Module (NoIR)
[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi With Fisheye Lens
B0298R
  • Discontinued, check alternative item B0265R, B0396.
  • Check Jetson Nano version SKU: B0298N
$159.99
  • This bundle includes an Arducam stereo camera HAT, two 8MP IMX219 camera module, and ribbon cables to connect them.
  • The stereo camera HAT allows you to use two Raspberry Pi cameras simultaneously on a single CSI-2 slot.
  • The stereo camera board frees you of any soldering in setting up your stereo vision with two Raspberry Pi camera module V2.
This Arducam 8MP Synchronized Stereo Camera Bundle Kit is capable of running two 8MP IMX219 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Raspberry Pi. It consists of two 8MP IMX219 camera module and an Arducam stereo camera HAT. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the RPi. You can use this bundle to build your stereo camera system for depth-related vision applications or upgrade your IMX219 stereo setup.
  • Robot navigation
  • 360° Camera
  • Objective tracking
  • 3D measurement
  • 3D reconstruction
  • Depth-related vision applications
- Camarray Stereo Camera HAT
  • Support Raspberry Pi 3B/3B+/4B, Pi HAT board style
  • Support 1/2 lane MIPI cameras input up-to 1Gbps/lane
  • Support 2 lane MIPI output up-to 1Gbps/lane
  • Support RAW8/RAW10/RAW12 output format, the output format automatically changes with the input format
  • Support Raspistill (preview) and Raspivid (processing) commands for 5MP/8MP/12.3MP pi cameras with half resolution combine
  • Support Arducam Pi cameras up to 16MP with proprietary camera driver with full resolution combine
  • HAT Size: 65 x 56 mm
- Camera
  • Sensor: IMX219
  • Optical Format: 1/4" (diagonal 7.857mm)
  • Resolution: 3280(H)×2464(V) 8MP
  • Pixel Size: 1.12 µm (H) × 1.12 µm (V)
  • IR Sensitivity: Visible light
  • Interface: 2-lane MIPI CSI-2
  • Default Lens Mount: M12 Mount Lens(PN#M32076M20)
  • Video Modes: RAW8/RAW10
  • Frame rate: Official driver-1642×1232@30fps with raspistill, 1920×1080@30fps with raspivid;    Arducam MIPI Camera driver-3264×2×2464@8fps 2592×2×1944@10fps 1920×2×1080@18fps
  • Board Size: 24mm x 24mm
- Lens
  • Format: 1/4 inch
  • Focal Length: 0.76mm
  • Aperture (F): F2.1
  • Field of View (FOV): 220° (H)
  • Mount: M12 Mount
  • Back Focal Length: 2mm
  • MOD: 0.2m
  • Dimension: Φ16×13.5mm
  • Weight: 5g
Package Includes
  • 1pcs Arducam Synchronized Stereo Camera HAT for Raspberry Pi
  • 2pcs 8MP IMX219 color camera module mounted with M12 lens
  • 2pcs Arducam 73mm 15pin to 22pin Ribbon Cable
  • 1pcs Arducam 150mm 15pin to 22pin Ribbon Cable
  • 4pcs M2.5*11mm Nylon Hex Standoffs
  • 4pcs M2.5 Nylon Nuts
  • 3pcs M2.5*6mm Nylon Screws
synchronized-stereo-pi-camera-hat-dual-blog-thumbnail
58 comments
Camarray – Arducam 8MP Synchronized Stereo Camera Bundle Kit
Introduction ​This Arducam 8MP Synchronized Stereo Camera Bundle Kit is capable of running two 8MP IMX219 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Raspberry Pi. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You […]
Arducam 8MP Synchronized Stereo Camera Bundle Kit (SKU: B0298R) Troubleshooting
Because the B0298R kit includes multiple components, any hardware or software problems will simply make it doesn’t work, and the troubleshooting process will be a bit complicated. Please refer to the following steps for a step-by-step diagnosis. 1.Check driver and camera enable First, check whether the driver is correct and whether the camera is enabled,Please refer to the Check […]
NOTE 1:
Raspberry Pi board is not included in the package.
NOTE 2:
The IMX219 cameras in this kit is a special version and cannot be used on Raspberry Pi or Jetson directly. Its connection to the Camarray HAT is required.
NOTE 3:
8MP IMX219 Synchronized Stereo Camera Bundle Kit supports official driver and Arducam MIPI Camera driver, the difference between the two drivers is as follows:
①The official driver has good image effect, but does not support full spelling.
The official driver supports official commands (raspistill and raspivid), can use the official ISP, has AWB, AE and other functions, the image effect is better.
However, it does not support full spelling, it is compressed half spelling (to ensure the same resolution after compositing, the resolution of each camera is compressed in the horizontal direction by half, but the field of view remains the same).
②Arducam MIPI Camera driver supports full spell, but no ISP, the image is poorer.
Arducam MIPI Camera driver supports full spelling, and the resolution in the horizontal direction is doubled after compositing, so the official ISP cannot be used.
Because there is no AWB, AE and other image processing functions, the image effect is poor (the default image will glow green).
NOTE 4:
Oscillator sharing requires extra cables, soldering skill needed or please use Arducam bundle kit
NOTE 5:
  2. The Camarray HAT requires different firmware for different Image sensors that are not natively working with your embedded systems. Your own IMX219 camera modules won’t directly work with it, and they are not easily interchangeable.
