Arducam Camera Module 3 Series for Raspberry Pi
We look to help everyone build low-cost embedded camera projects for hundreds of real-world applications.
All cameras are based on SONY 12MP IMX708 Back-illuminated, stacked CMOS image sensor. Built-in High signal-to-noise ratio (SNR) and 2D Dynamic Defect Pixel Correction (DPC). Allows HDR mode output (up to 3 megapixels)
At present, we have designed and released Official Camera Module 3 with Arducam Acrylic Case Kit, USB UVC Camera Kit, and Fixed Focus Camera Module 3. These camera variants can assist you in capturing high-quality images in a multitude of scenarios and situations, enabling you to complete your projects more effectively.
Less for us, more for you. Whether it’s an official camera or an Arducam camera, both can provide you with immense freedom. We want it to help push the Raspberry Pi and embedded ML/MV forward, everything about this camera will be truly open source.
Image Sensor | IMX708 |
Resolution | 11.9MP |
Optical Size | 1/2.43(7.4mm sensor diagonal) |
Number of effective pixels | 4608(H) × 2592(V) |
Pixel Size | 1.4μm × 1.4μm |
Interface | MIPI CSI-2 Interface |
Color Filter | Color |
Common Video Mode | 1080p50, 720p100, 480p120 |
Output Format | RAW10 |
The six Camera Modules 3 released by Raspberry Pi all feature Autofocus, which can meet shooting needs at different distances. But fixed-focus has faster imaging speed, more stable image focus, and higher quality images. Arducam has currently released three cameras with different degrees:
1. Arducam 66°(H) Fixed-Focus Camera Module
2. Arducam 102°(H) Wide Angle Fixed-Focus Camera Module
3. Arducam 120°(H) M12 Lens Ultra Wide Angle Fixed-Focus Camera Module
Do you need an elegant enclosure for your camera? Great! Arducam camera acrylic cases for Raspberry Pi are fully compatible with the official camera module 3.
Here old friend comes, Arducam Multi-Camera Kit for Camera Module 3 is now available. Based on Arducam’s mature multi-camera solution, we have designed a four-camera synchronization kit for the IMX708 camera, which will greatly enhance the effectiveness and achievement of your depth vision projects.
The MIPI CSI interface is fast and stable, but its compatibility and convenience are far from that of the USB interface compatible with the UVC protocol. Compatibility with UVC means plug-and-play. Our UVC USB kit based on the IMX708 sensor is designed to achieve universal compatibility across all platforms and systems.
After the official release of the third-generation camera module with phase autofocus by Raspberry Pi, the Arducam team recently released an IMX708 autofocus module with ultra-high cost performance. The camera module uses a focus method that combines PDAF and CDAF and is a powerful assistant for your various projects.
First things first We just released two new IMX708 12MP Camera UVC buddle kits. One is with a standard lens and the other is with a 102° wide-angle lens. Inspiration MIPI CSI-2 equipped RPi camera modules had long missed the chance to turn webcams. It’d been a pity for many RPi fans. Because Pi cameras […]
What is it like when you take a panoramic view photo with your cell phone? Hold tight to the phone and move slowly from left to right, and finally see a zigzag edge on the joints …… 🙁 How about the below one? Taken by four IMX708 12MP cameras standing still. Not bad, huh? So, […]
Fancy an upgrade, eh? The old V1/V2 setup of yours is officially outdated, and the next camera project you’ve been thinking about can finally come to fruition, and you have just found one more reason to start that OpenCV course you were hesitant about, all because of the V3 cameras. The official Camera Module V3 […]
