ArduCAM Pinouts
Pin definition:
Signals Description Signals Description
+3.3V +3.3V from shield +5V +5V from Arduino
D1 3.3V logic version of D1 D0 3.3V logic version of D0
D3 3.3V logic version of D3 D2 3.3V logic version of D2
D5 3.3V logic version of D5 D4 3.3V logic version of D4
D7 3.3V logic version of D7 D6 3.3V logic version of D6
D9 3.3V logic version of D9 D8 3.3V logic version of D8
+3.3V +3.3V from shield GND Ground
IO1 Expansion GPIO1 IO0 Expansion GPIO0
D11 3.3V logic version of D11 D13 3.3V logic version of D13
IO2 Expansion GPIO2 D12 3.3V logic version of D12
IO3 Expansion GPIO3 D10 3.3V logic version of D10
IO5 Expansion GPIO5 IO4 Expansion GPIO4
A0 3.3V logic version of A0 A1 3.3V logic version of A1
A2 3.3V logic version of A2 A3 3.3V logic version of A3
A4 3.3V logic version of A4 A5 3.3V logic version of A5
GND Ground GND Ground
Arduino board use IOs to emulate parallel bus to access ArduChip internal registers and external LCD registers. User should instantiate the ArduCAM and UTFT class which use parallel bus before the setup routine. The function of each signal list as follows:
Signals Functions
D[7:0] Parallel bus data[7:0]
A0 Parallel bus RD, active low
A1 Parallel bus WR, active low
A2 Parallel bus RS
A3 Parallel bus CS, active low
A4 I2CSDA for Camera Module
A5 I2CSCL for Camera Module
D10 LCD chipselect, active low
D9 SD/TF chipselect, active low
D11 SPI MOSI
D12 SPI MISO
D13 SPI SCLK
The following is a piece of the code for demonstration of the instantiate the ArduCAM and UTFT class.
#define SD_CS 9
//UTFT(byte model, int RS, int WR, int RD, int CS)
UTFT myGLCD(ITDB32S,A2,A1,A0,10);
//ArduCAM(byte model,int RS, int WR, int RD, int CS)
ArduCAM myCAM(OV7670,A2,A1,A0,A3);
void setup()
  // Setup I2C port
  Wire.begin();
  if (!SD.begin(SD_CS))
    while (1);
  // Setup ArduChip
  myCAM.InitCAM();
  // Setup the LCD
  myGLCD.InitLCD();
  ShowStart();
  delay(2000);
Leave a Reply
