[Discontinued] Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera with Base for Raspberry Pi 4/3B+/3
64MP Camera and Pan-Tilt Kit for Raspberry Pi
B0399B0283
  • PTZ-capable: pan-tilt bracket with a camera that supports digital zooming.
  • 64-megapixel: ultra high resolution for Pi.
  • Autofocus: AF/Manual/Continuous-AF out of the box.
  • Easy to use: compatible with the official software. (libcamera)
  • V1/V2 ready: bracket also supports any camera in v1/v2 form factors.
arducam shipping payment 1
$86.98
The most powerful pan-tilt camera kit ever made for Raspberry Pi.With our 64MP-AF camera, a handy PT system, and the help of OpenCV, you can build a mini face/movement tracking solution like this:
The camera itself works with most Pi models, older ones like Pi 2 or Pi 0 may suffer from performance drops. And the PT kit is also compatible with both the official V1/V2/HQ cameras and Arducam OV5647/IMX219/IMX477 series.
More about our PTZ camera solutions >
Optical Size 1/1.7" 9.25mm Diagonal(7.4×5.55mm)
Focus Type Manual/Auto
Sensor Resolution 9152×6944
Color Filter Quad Bayer Coding(QBC)
Focus 8cm~INF
Focal Length 5.1mm
View Angle 84 Degrees (Diagonal)
Dimensions 25×24 mm
Sensor Output Formats RAW10
Video Modes (Camera Module)* 9152×[email protected], 8000×6000@3fps, 4624×3472@10fps, 3840×2160@20fps, 2312×1736@30fps, 1920×1080@60fps, 1280×720@120fps
Platform Output Formats JPEG/YUV/RGB/RAW10
Video Modes (on Raspberry Pi) 1080p30,720p60 and 640×480p60/90
Supported Platforms Raspberry Pi 5/4B/Pi 2/3/CM3/CM4/CM5/Zero W/Zero 2 W
Raspberry Pi OS bookworm/bullseye(32-bit/64-bit) 01/28/22 or later releases
Specifications - Pan-Tilt Kit
Digital Servo
  • Torque: 0.6 kg/cm at 3.6V, 0.8 kg/cm at 4.8V
  • Operating Speed: 0.13sec/60° at 3.6V, 0.09sec/60° at 4.8V
  • Operating Voltage: 3.6v~4.8v
  • Operating Current: <350mA
  • Dead Band: 3 usec
  • Dimension: 20mm x 8.75mm x 22mm
Customized Control Board
  • PWM resolution: 12-bit
  • Communication interface: I2C
  • Operating voltage: 3V-5V
  • Dimension: 38mm x 28mm
Documentations
The arducam 64MP cameras can only get maximum resolution and video streaming on Pi4 and CM4 platforms. The resolution and video streaming of the camera will be limited on other Raspberry Pi platforms
Packing Including
  • 1 x 64MP-AF Camera
  • 1 x Pan-Tilt Kit
*To use the camera on Pi Zero and 2 W, you need this.
FAQs
Does the PT kit work on other platforms other than Pi?
Yes, but it needs assorted driver software.
Can I make manual pan/tilt adjustments?
Yes.
