Check alternative camera B0167B12
This camera is a PTZ camera bundle kit based on the ov5647 sensor, we have made some changes on the basis of the sensor. PTZ is an abbreviation for pan, tilt, and zoom and reflects the movement options of the camera, and a pan–tilt–zoom camera (PTZ camera) is a camera that is capable of remote directional and zoom control. A PTZ camera is not a still camera. Instead, it could move the camera and the lens, and that means a single camera can be used to monitor places that should be covered by multiple ones. You can save a lot of cost and time in purchasing and deploying the camera if a PTZ camera can handle the job. With its moveable lens, you will also be able to zoom the camera to see a specific area that you are interested in. To conclude, it’s “do more with less.”
| Sensor | Omnivision OV5647 sensor |
| Sensor size | 1/4” (OV5647) |
| Resolution | 5MP 2592×1944 |
| Video | 1080p 30 fps, 720p 60fps, 480p 90fps |
| Focal-Length | 3.2-11.1mm±5% |
| F No. | W:1.6-T:3.3±5% |
| Focus Type | Front group: focus Back group: Zoom |
| M.O.D | 0.8m |
| Dimension | 36mm x 36mm |
| Pan and Tilt Range | 0-180° |
| Zoom Range (Wide => Tele) | 2317 steps 0.00396mm/step |
| Focus Range(Near => Far) | 3009 steps 0.0047mm/step |
1. 5MP OV5647 / 8MP IMX219 Camera No. Items Specification 1 F No. W:1.6-T:3.3±5% 2 Focal-Length 3.2-11.1mm±5% 3 Optical Back Focal Length 5.8±0.1 4 Mechanical Back Focal Length 13.45±0.2 5 TTL 52.14±0.2 6 Image Circle ∅6.9 7 Lens Structure 6G3P 8 Mount ∅14 9 FOV 1/2.7”(16:9): H(113~30),V(60~16),D(137~34) 1/3”(4:3): H(91~25),V(66~18),D(120~30) 1/4”(4:3): H(67~18),V(49~13),D(90~22) 10 M.O.D 0.8m 11 […]
Why add a camera to your 3D printers? Most 3D models take more than a few hours to print, so you may wish to leave the 3D printer at some point in the printing process. Using an Arducam camera to monitor 3D printing can make you pay close attention to your creation. Since most cameras […]
