The official Pi HQ camera is only available in one model. It doesn’t come with a lens and it is also not easy for the users to find a case. To solve these pain points, Arducam released this complete camera bundle, an IMX477 camera board with a 6mm CS lens, a customized metal enclosure, a tripod stand and a set extension adapter. Through this expansion, you will have more choices, and at the same time, the application range of your camera will be extended.
Application
- DSLR Camera Control
- Remote Viewing Camera
- Time-lapse Machine
- Security System
- Smart Video Doorbell
- Face Recognition
- Instant (Polaroid-Style) Camera, etc.
| Camera Sensor | Sony 12.3MP IMX477 |
| Optical Format | 1/2.3″ (diagonal 7.857mm) |
| Resolution | 12.3MP |
| Active Pixels | 4056(H) x 3040(V) |
| Pixel Size | 1.55um x 1.55um |
| Frame Rates | Full resolution@60fps(normal), 4K2K@60fps, 1080p@240fps Full resolution@40fps (12bit normal) Full resolution@30fps (DOL-HDR, 2 frames) |
| Shutter Type | Rolling Shutter |
| Interface | 2-lane MIPI CSI-2 |
| Default Lens Mount | CS-Mount |
| Lens Parameters | F/No: 1.2, Focal Length: 6mm, MOD: 0.2m, Back Focal Length: 7.53mm, Dimension: Φ30×31mm |
| Focus Type | Manual |
| Field of View(FoV) | 65°(H) |
| IR Sensitivity | Integral IR fliter, visible light only |
| Board Size | 38mm x 38mm |
| Hole Pitch | Compatible with 29mm, 30mm, 34mm |
| Peak Current | 300mA |
- 1 x complete 12.3MP IMX477 color camera mounted in a metal encolsure
- 1 x 1/2.3 inch 6mm focal length CS-mount lens and
- 1 x HDMI-CSI camera adapter board with 60mm/2.36inch 15 pin camera cable
- 1 x 1m high-speed HDMI cable
- 1 x mini tripod stand
- 1 x 73mm/2.9inch 15 pin to 22 pin camera cable for pi zero&w
- 2 sets M2.5 nylon standoffs, screws and nuts
- Raspberry Pi board is not included in the package
- Our IMX477 camera module support 4-lane in hardware, but the 4-lane camera driver requires extra customization. Here is why:
Standard Raspberry Pi and Jetson Nano/Xavier NX can’t physically support a 4-lane connection (both of them only have 2-lane CSI connectors). Only the Raspberry Pi Compute Module and some 3rd party Jetson Carrier Boards come with 4-lane hardware support. Therefore, it’s not a general need.
Extra works, specifically camera drivers, are required for a 4-lane connection other than the 4-lane physical connector. And the drivers are limited by the performances of the platform itself. For example, 4-lane can’t unlock 4k video on Raspberry Pi because the VideoCore does not currently support it. Jetson Nano is also to some extent limited because of the encoding capabilities. You need to make sure you really need it.
- This camera module supports the latest Raspberry Pi OS Bullseye (released on Jan 28th, 2022) and libcamera apps, for the previous Raspberry Pi OS (Legacy) users, contact us at [email protected].
12MP IMX477 Standard Camera Module
Introduction Arducam IMX477 cameras support all Raspberry Pi camera models. Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero, and more. Unlike the official high quality camera has only one hole pitch, Arducam IMX477 cameras offer 3 hole pitches 29mm, 30mm, 34mm. compatible with standard industrial camera enclosure. What’s more, they have a 4-lane MIPI CSI-2 interface, more […]
Part No CS17320M12 CS2316ZM02 CS2308ZM05 CS2008ZM05A CS1812ZM03 CS2325ZM01 CS1806ZM06 Size(mm) NOTE 1: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included. NOTE 2: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.Lens Options
CS-Mount Lens
SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029 Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' EFL(mm) 3.2 16.00 8.00 8.00 12.00 25.00 6.00 BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03 F/NO 2.0 1.2 1.4 1.2 1.6 1.2 1.4 HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65° MOD 0.30m 0.20m 0.30m 0.20m 0.20m 0.20m 0.30m 28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
How to Purchase
