[Discontinued] Arducam 70 Degree 1/2.3
[Discontinued] Arducam 70 Degree 1/2.3" M12 Lens with Lens Adapter for IMX477 High Quality Camera
[Discontinued] Arducam CS-Mount Lens Bundle for Raspberry Pi HQ Camera, 6mm Focal Length Wide Angle CS Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam Complete High Quality Camera Bundle for Raspberry Pi and Pi zero , 12.3MP 1/2.3 Inch IMX477 Camera Module with 6mm CS-Mount Lens, Metal Enclosure, Tripod and HDMI Extension Adapter
B0241
Discontinued, check alternative item B0240.
  • Clearer Images: Based on 12.3MP IMX477 sensor. Max still resolution 4056(H) x 3040(V)
  • No Hassle: Including a 1/2.3″ 6mm focal length CS lens and an industrial?metal enclosure mounted on the camera board, also comes with a mini tripod stand and a set HDMI extension adapter
  • Wide Compatiblity: It supports all Raspberry Pi camera models
  • For Nvidia Jetson Nano and Xavier NX, you can search for B0249 / B0250 to get the Jetson camera bundle
  • For PC /laptop, you could purchase the HQ UVC camera module?B0280?(with 6mm CS Mount Lens) or?B0288 (with Varifocal C Mount Lens) directly
$99.99
The official Pi HQ camera is only available in one model. It doesn't come with a lens and it is also not easy for the users to find a case. To solve these pain points, Arducam released this complete camera bundle, an IMX477 camera board with a 6mm CS lens, a customized metal enclosure, a tripod stand and a set extension adapter. Through this expansion, you will have more choices, and at the same time, the application range of your camera will be extended.
  • DSLR Camera Control
  • Remote Viewing Camera
  • Time-lapse Machine
  • Security System
  • Smart Video Doorbell
  • Face Recognition
  • Instant (Polaroid-Style) Camera, etc.
    Camera Sensor Sony 12.3MP IMX477
    Optical Format 1/2.3" (diagonal 7.857mm)
    Resolution 12.3MP
    Active Pixels 4056(H) x 3040(V)
    Pixel Size 1.55um x 1.55um
    Frame Rates Full resolution@60fps(normal), 4K2K@60fps, 1080p@240fps Full resolution@40fps (12bit normal) Full resolution@30fps (DOL-HDR, 2 frames)
    Interface 2-lane MIPI CSI-2
    Default Lens Mount CS-Mount
    Lens Parameters F/No: 1.2, Focal Length: 6mm, MOD: 0.2m, Back Focal Length: 7.53mm, Dimension: Φ30×31mm
    Focus Type Manual
    Field of View(FoV) 65°(H)
    IR Sensitivity Integral IR fliter, visible light only
    Board Size 38mm x 38mm
    Hole Pitch Compatible with 29mm, 30mm, 34mm
    Peak Current 300mA
    • 1 x complete 12.3MP IMX477 color camera mounted in a metal encolsure
    • 1 x 1/2.3 inch 6mm focal length CS-mount lens and
    • 1 x HDMI-CSI camera adapter board with 60mm/2.36inch 15 pin camera cable
    • 1 x 1m high-speed HDMI cable
    • 1 x mini tripod stand
    • 1 x 73mm/2.9inch 15 pin to 22 pin camera cable for pi zero&w
    • 2 sets M2.5 nylon standoffs, screws and nuts
    • Our IMX477 camera module support 4-lane in hardware, but the 4-lane camera driver requires extra customization. Here is why:
      1. Standard Raspberry Pi and Jetson Nano/Xavier NX can’t physically support a 4-lane connection (both of them only have 2-lane CSI connectors). Only the Raspberry Pi Compute Module and some 3rd party Jetson Carrier Boards come with 4-lane hardware support. Therefore, it’s not a general need.
      2. Extra works, specifically camera drivers, are required for a 4-lane connection other than the 4-lane physical connector. And the drivers are limited by the performances of the platform itself. For example, 4-lane can’t unlock 4k video on Raspberry Pi because the VideoCore does not currently support it. Jetson Nano is also to some extent limited because of the encoding capabilities. You need to make sure you really need it.
    • This camera module supports the latest Raspberry Pi OS Bullseye (released on Jan 28th, 2022) and libcamera apps, for the previous Raspberry Pi OS (Legacy) users, contact us at [email protected].
    12MP IMX477 Standard Camera Module
    Introduction Arducam IMX477 cameras support all Raspberry Pi camera models. Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero, and more. Unlike the official high quality camera has only one hole pitch, Arducam IMX477 cameras offer 3 hole pitches 29mm, 30mm, 34mm. compatible with standard industrial camera enclosure. What’s more, they have a 4-lane MIPI CSI-2 interface, more […]
    Lens Options
    CS-Mount Lens
    SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029
    Part No
    CS17320M12
    CS2316ZM02
    CS2308ZM05
    CS2008ZM05A
    CS1812ZM03
    CS2325ZM01
    CS1806ZM06
    Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
    EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
    BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
    F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
    HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
    MOD 0.30m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
    Size(mm)
    28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
    NOTE 1: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
    NOTE 2: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.
    How to Purchase
