Arducam IMX219 Wide Angle IR Sensitive (NoIR) Camera Module for NVIDIA Jetson Board
Arducam 8MP Pan Tilt Zoom PTZ Camera for Raspberry Pi 4/3B+/3 and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam IMX219 Wide Angle Camera Module for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0179
  • More Than HD: This camera adopts 1/4” 8 Megapixel IMX219 sensor for sharp image, Max. still resolution is 3280 x 2464 pixels.
  • Wider Angle of View: This camera module has 175°(D) wide-angle M12 Lens, which provides a much wider Field of View compared to the stock lens on V2 camera module.
  • IR Sensitivity: Integral IR filter, visible light only; Focal Length: 2.5 mm; View Angle:
  • 170°(D) x 155°(H) x 115°(V)
was $35.99 Special Price $19.99
This Arducam IMX219 camera module is mainly designed for NVIDIA® Jetson Board and also can be used on other hardware like ARM, DSP, FPGA, etc. The highlight of this camera is its wide field of view.
    Note:
    For the Orin Nano/Orin NX, a 22-22 pin FFC cable is included. If you are using an AGX Orin, an additional camera adapter (B0472) is required.
    This camera does not support the standard Raspberry Pi models (like Raspberry Pi 3/3B+/4).
    ★KERNEL CAMERA DRIVER USED
  • Sony 8MP IMX219 Sensor
  • Optical Format: 1/4 inch
  • Data Format: RAW8/RAW10
  • EFL: 1.3mm
  • F.NO: 2.0
  • Focus Type: Fixed Focus
  • View Angle: 175(D) x 155(H)  x 115(V)
  • Interface: MIPI CSI-2 2-lane/4-lane
  • IR Sensitivity: Integral IR Filter, visible light only
Image Sensor IMX219
Still Resolution 8 Megapixels
3280x2464@21fps, 3280x1848@28fps, 1920x1080@30fps, 1640x1232@30fps, 1280x720@60fps
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 1.3mm
F.NO F2.0
Field of View(FOV) 155°(H)×115°(V)×175°(D)
Electrical & Mechanical
Camera Board Size 25 x 24mm
Peaking Current 300mA
  • 1pcs Arducam IMX219 Wide Angle Camera Module for NVIDIA Jetson Board
  • 1pcs 15cm 15-22pin FPC cable
  • 1pcs 15cm 22-22pin FPC cable
  • How to use the camera on NVIDIA Jetson Orin NX/AGX Orin
  • How to use the camera on Jetson
    IMX219 – 8MP Camera
3D drawing.step
2 comments
Lens  options
SKU Format FOV on 1/4” sensor Focal Length
LN006 1/4’’ 100° 1.8mm
LN008 1/2.5’’ 140° 1.56mm
LN011 1/2.5’’ 45° 4mm
LN012 1/2.5’’ 55° 3.6mm
LN013 1/2.7’’ 75° 2.8mm
LN014 1/2.7’’ 90° 2.1mm
LN015 1/4’’ 63° 3.2mm
